Solve Thermodynamics Problem: Determining Exit Temp & Velocity
  • Thread starter Thread starter bill nye scienceguy!
    Thermodynamics
The discussion focuses on solving a thermodynamics problem involving a nozzle with a gas stream at an initial temperature of 800K and pressure of 300kN/m², expanding adiabatically to a pressure of 158kN/m². The exit temperature was calculated using the formula T2/T1 = (P2/P1)^[(n-1)/n], confirming the application of the adiabatic process. However, the user struggled to determine the exit velocity using the steady flow energy equation, which is indeed the correct approach for this calculation.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the steady flow energy equation
  • Knowledge of the ideal gas law
  • Basic principles of fluid dynamics
  • Study the application of the steady flow energy equation in detail
  • Learn about the derivation and use of the adiabatic process equations
  • Explore the concept of specific heat ratios in thermodynamics
  • Investigate methods for calculating exit velocity in nozzle flow scenarios
Students and professionals in mechanical engineering, particularly those specializing in thermodynamics and fluid mechanics, will benefit from this discussion.
A nozzle is supplied with steady gas stream at temperature = 800K and pressure = 300kN/m^2. If the gas expans adiabatically through the nozzle to a pressure of 158kN/m^2 following the law Pv^1.4 = constant, determine the exit temperature and velocity of the gas flow.
I've already found the exit temperature using:
so how would i go about finding the exit velocity? I tried using the steady flow energy equation but to no avail.
Why not? I think that the steady flow energy equation will give you the answer.
10K
10K
