Venusian Rotation: Retrograde & Axial Tilt 178° Explained
  • Context: Graduate
  • Thread starter Thread starter DaveC426913
    Rotation
The discussion revolves around the rotation and axial tilt of Venus, specifically addressing the implications of its retrograde rotation and the measurement of its axial tilt at approximately 178 degrees. Participants explore the definitions and references used to describe these characteristics, considering both external viewpoints and the relationship between rotation and revolution.
  • Some participants question whether Venus' retrograde rotation is defined from an external point of view or in relation to its revolution around the Sun.
  • There are differing opinions on whether Venus would continue to rotate clockwise or counterclockwise if the Sun were removed, with some asserting it would rotate counterclockwise.
  • Participants discuss the implications of Venus' axial tilt being defined with respect to its magnetic poles, suggesting that the tilt measurement could be seen as upside down due to its retrograde rotation.
  • One participant argues that if Venus is considered both retrograde and upside down, it may be a case of double-dipping in definitions.
  • Another viewpoint suggests that the solar day being shorter than the sidereal period indicates that Venus is indeed rotating clockwise, despite its retrograde classification.
  • There is a suggestion that the axial tilt of ~178 degrees could be interpreted differently, questioning why it is not described as ~2 degrees instead.
Participants express multiple competing views regarding the definitions and implications of Venus' rotation and axial tilt. The discussion remains unresolved, with no consensus reached on the interpretations of these characteristics.
Participants highlight the complexity of defining retrograde motion and axial tilt, noting that these definitions may depend on the chosen reference frame and the relationship between rotation and revolution. The discussion also reflects uncertainty regarding the implications of magnetic fields on these definitions.
DaveC426913
2025 Award
This came up in https://www.physicsforums.com/showthread.php?t=119891", and now I'm not sure of my answers.
1] Venus' rotation is retrograde. Is that taking into account its revolution about the Sun, or is that still true from and external point-of-view?
i.e.: If the Sun were suddenly whisked out of existence, and Venus were left adrift on a straight path, it would continue to rotate slowly on its axis:
a] clockwise
b] counterclockwise
2] Venus' axial tilt is ~178 degrees. this is because
a] Axial tilt is always defined with North magnetic pole being at the top. Since on Venus, the South magnetic pole is at the top, the axial tilt is measured as upside down (i.e. ~180 from upright).
b] Axial tilt is always defined with North rotating counterclockwise. Because Venus is retrograde, its "bottom" pole is actually the one rotating counterclockwise, and thus is considered the North pole, which means Venus is upside down (i.e. ~180 from upright).
Here's the thing about 2b. If true, you can't say Venus is BOTH retrograde AND upside down; it can be considered one OR the other, but to count both is basically double-dipping.
Astronomy news on Phys.org
I only have a few minutes, so I'll try to think about your other questions later, but here's my basic reasoning. Try drawing out the orbit of venus as seen from above the solar system's north pole. It will be going counter-clockwise around this orbit as you said. Now, supposing that the period of rotation is very close to the period of revolution, which direction would it have to rotate in order to have a very long (much longer than its rotation period) solar day? I believe the answer is that it would have to rotate counter-clockwise, the same as the direction of revolution. To see this, try moving venus about its orbit without rotating it. What direction would it have to turn to keep one point on the surface always pointing to the sun?
Anyway, we know that its solar day is not much longer than its sidereal period -- in fact, it's shorter. This suggests that it really is rotating clockwise and that both effects, the motion about the sun and about its axis, are acting to move the sun across the sky from west to east as seen from an observer on Venus.
Does Venus even have a magnetic field?
Not a measurable one, it seems. As you're probably implying, a planet's magnetic field doesn't determine whether or not its rotation is retrograde. My understanding is that its rotation is always compared to one direction perpendicular to the plane of the ecliptic. This should yield the following answers to Dave's questions:
1) a (clockwise)
2) b (no consideration of magnetic field)
In this context, "north" defined by rotation and has no terminological connection to the magnetic pole (which need not align with the rotation axis).
If we're using an external reference to define "retrograde", I don't see why it can't have a ~180 degree axial tilt and a retrograde rotation. It is true, I believe, that the statements are redundant and "retrograde or prograde" can be determined directly from the axial tilt.
SpaceTiger said:
... supposing that the period of rotation is very close to the period of revolution, which direction would it have to rotate in order to have a very long (much longer than its rotation period) solar day? I believe the answer is that it would have to rotate counter-clockwise, the same as the direction of revolution.
: slaps forehead : Of course! It HAS to be prograde for the day to match up with the year! What was deducible with the facts I already knew!
thus, it is only retrograde wrt the Sun.
Thanks!
1) a (clockwise)
No, it would be counter-clockwise. As we just determined, Venus' rotation about its axis from a PoV external to the SS is still CCW. If the Sun were whisked away, it would continue in a straight line, and contimue its slow CCW rotation.
Why do they list its axis as ~178 degrees? Why wouldn't they say ~2 degrees?
Perhaps my wording was poor. The part of my post you quoted was followed soon by:
SpaceTiger said:
Anyway, we know that its solar day is not much longer than its sidereal period-- in fact, it's shorter. This suggests that it really is rotating clockwise...
We're looking down on the solar system from a direction above the plane of the solar system -- that is, an external reference frame. From this vantage point, the planets revolve counterclockwise around the sun and Venus rotates clockwise about its axis. Removing the sun would do nothing to the direction of Venus' rotation.
Because Venus is rotating in the opposite direction of the other planets. A rotation that was perfectly prograde (or, prograde and aligned with the ecliptic) would have axial tilt 0 degrees and one that was exactly retrograde would have 180 degrees. The two things are redundant, not interdependent -- that is, a retrograde planet with ~180 degrees axial tilt is not the same as a prograde planet with ~0 degrees axial tilt.
9K
  • · Replies 21 ·
