How do I correctly calculate linear speed in a tilted pinball machine problem?
  • Thread starter Thread starter FlipStyle1308
    Machine
The discussion revolves around calculating the linear and angular speeds of a pinball in a tilted pinball machine, involving concepts of potential energy, kinetic energy, and rotational dynamics.
  • Mixed
  • Participants explore the relationship between elastic potential energy and kinetic energy, questioning the inclusion of rotational kinetic energy in the calculations. There are attempts to clarify the equations used and the definitions of variables involved.
Some participants have offered guidance on the need to include rotational kinetic energy and to correctly compute the moment of inertia. There is ongoing confusion regarding the correct application of formulas and the interpretation of numerical values.
Participants question the feasibility of the given dimensions and heights in the problem setup, indicating potential discrepancies in the scenario described.
FlipStyle1308
A pinball (solid sphere of mass = 0.1 kg, outer radius = 0.1 m) is cocked back 0.8 m on a spring (k = 50 N/m), and fired onto the pinball machine surface, which is tilted. When the pinball is 2.5 m above its initial location (on the way up), find its linear and angular speeds.
I used PEsp = KE, which I got 16 = (0.5)(0.1)(v^2), and got 17.89, for my linear speed, and got that wrong. I know that once I get my linear speed, I plug that into an equation to get angular speed, but I would like to know how to get this linear speed correct. Thanks!
2.5 meters?? Wow, that's a huge pinball machine!:biggrin:
You have forgotten to include the kinetic energy of rotation. You must add to the final kinetic energy [itex]{1 \over 2} I \omega^2[/itex]and use [itex]\omega = {v \over r}[/itex]
So PEsp = KE, 16 = (1/2)(0.1)(v^2) + (1/2)(0.1)(0.1^2)(v/0.1)?
I am confused by your second term! First, you need to compute the moment of inertia I of a sphere (you seemed to have use the mass instead of I!) Also, the (v/r) must be squared. And I don't know what you (0.1)^2 means.
Okay, my mistake! So is velocity = 12.649 m/s, and angular speed is 126.49 rad/s? I got this wrong...I don't know why.
Bump! Anyone able to help me finish off this problem?
All your numerical values, except the mass seems rather suspicious. A ball with a diameter of 20 centimeters going 2.5 meters up in a pinball machine?
[tex]P_{ela}=P_{grav}+K_{lin}+K_{rot}[/tex]
the elastic potential energy is converted to gravitational potential energy and linear and rotational kinetic energy giving
[tex]kx^2=2mgh+mv^2+I{\omega}^2[/tex]
then use
[tex]v=\omega r[/tex]
to subs for [itex]v[/itex] and solve for [itex]\omega[/itex]
What is x?
The first equation in my post states that the stored elastic energy in the spring is converted into the gravitational potential energy of the ball, the linear kinetic energy of the ball and the rotational kinetic energy of the ball.
10K
11K
  • · Replies 50 ·
