HELP: A complex valued power series
The forum discussion centers on evaluating the complex-valued power series defined by \(\frac{2n+1}{2^n} i^n\) and proving its sum equals \(\frac{4}{25} + \frac{22}{25}i\). The user, Hummingbird25, attempts to separate the series into two components, \(S_0\) and \(S_1\), and employs differentiation techniques based on the geometric series formula. A more efficient method is suggested, involving multiplying the series by \(x\) to simplify the computation without differentiation, ultimately leading to a clearer solution.
  • Understanding of complex numbers and their properties
  • Familiarity with power series and convergence criteria
  • Knowledge of geometric series and their sums
  • Basic differentiation techniques in calculus
  • Study the properties of complex power series and their convergence
  • Learn about geometric series and their applications in summation
  • Explore alternative methods for summing series, such as generating functions
  • Investigate the differentiation of power series and its implications
Mathematicians, students studying complex analysis, and anyone interested in advanced series summation techniques.
Hummingbird25
Hi All,
I have this here power series which is complex valued
[tex]\frac{2n+1}{2^n} i^n = \frac{4}{25} + \frac{22}{25}i[/tex]
My task is to prove that this power series has the above mentioned sum.
To do this I separate the sum into two sums
[tex]S_0 + S_1 = (i/2)^n + 2* (i/2)*n*(i/2)^{(n-1)}[/tex]
the first is easy since can use
[tex]S_0 = \frac{1}{1-(i/2)} = 4/5+2/5i[/tex]
The second is quite hard to compute. I'm to told that I need to differentiate, by using the sum
[tex]\sum _{n=0} ^{\infty} x^n = \frac{i}{2}[/tex]
then by differentiating the sum I get
[tex]f'(x) = \sum_{n=0} ^{\infty} n x^{n-1}[/tex]
In my textbook it says that x^n converge to 1/(1-x)
Then since |i/2| < 1, I differentiate both sides of the equation.
[tex]\frac{1}{(1-(i/2))^2} = \sum_{n=0} ^{\infty} n (i/2)^{n-1}[/tex]
I multiply by i/2 on both sides of the equation to get.
[tex]\frac{i/2 * 1}{(1-(i/2))^2} =\sum_{n=0} ^{\infty}(i/2) n (i/2)^{n-1}[/tex]
then since |i/2| < 1, then I multiply by a factor of two on both sides of the equation
[tex]2\frac{i/2 * 1}{(1-(i/2))^2} = \sum_{n=0} ^{\infty}2 (i/2) n (i/2)^{n-1}[/tex]
[tex]-16/25 + 12/25i = \sum_{n=0} ^{\infty}2 (i/2) n (i/2)^{n-1}[/tex]
Finally [tex]\frac{4}{5}+ \frac{2}{5i}+ (\frac{-16}{25} + \frac{12}{25i}) = \frac{4}{25} + \frac{22}{25}i[/tex]
I have the feeling that I'm doing something wrong?
Sincerely
Hummingbird25
Hummingbird25 said:
Hi All,
Sincerely
Hummingbird25
Sorry, I don't really have the time to really scrutinise the working you gave. There does seem to be a little typo in the LaTex, but it seems generally OK.
There's a much easier way than differentiation to work out sums of the form
[tex]S = \sum{nx^{-n}}[/tex] or variants on the theme.
Just multiply by x to get
[tex]Sx = \sum{nx^{1-n}}[/tex]
and compare like powers of Sx to S term by term.
You will find that [tex]Sx - S = S(1-x)[/tex] will amount to a very easy geometric progression and you can just divide that by (1-x) to find S.
Much easier than differentiation, IMHO.
