Calculating Velocity & Distance Over 1 ms
  • Thread starter Thread starter Poposhka
    Velocity
The discussion revolves around calculating the velocity and distance of a 1 kg object subjected to a force of 1 Newton over a time interval of 1 millisecond. Participants are exploring the implications of Newton's second law and the relationships between force, mass, acceleration, velocity, and distance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conversion of time units and the implications of constant acceleration on distance and velocity calculations. Questions arise about the correctness of initial calculations and the interpretation of acceleration over different time intervals.
There is ongoing exploration of the calculations involved, with some participants providing alternative perspectives on the formulas used. Several participants question the original poster's calculations and suggest clarifications regarding the application of physics principles.
Some participants highlight potential misunderstandings regarding the definitions of acceleration and the effects of time intervals on calculations. The original poster's goal of achieving higher resolution in their programming context is noted, as well as the need for careful consideration of unit conversions.
Poposhka
hey all, I'm pretty ignorant when it comes to physics.. so i have a question for you physics braniacs.
If 1 N is 1 kg m / s^2, meaning the force required to accelerate a 1 kg object at 1 m/s^2, then how much does 1 N accelerate a 1 kg object over 1 millisecond?
I googled for 1 m/s^2 in m/ms^2 and the result is as expected 10^-6 = 1 / (1000*1000). I plugged this into a formula, and i come up short.
at t=10 the velocity of a 1 kg object should be 10 m/s, and the distance traveled is 55 m.
But if i calculate velocity and position at each millisecond, the resulting velocity at t=10 s is 0.01 m/ms^2 = 10 m/s (which is correct) but my distance traveled is only 50.01 m.. why is that?
please slap around my physics deprived head a bit.
[edit]
I should add that the reason i want to calculate velocity and distance traveled each millisecond is that I'm making a C++ program to describe some functions, but doing it each second does not give me high enough 'resolution'.
a millisecond is 10^-3 s not 10^-6
try that see if it works
Why would the acceleration be different at 1ms or 1hour?
You have a constant force applied to a constant mass, therefore the acceleration is constant. It starts the instant the force is applied to the mass and continues until the force ends.
The quantities of interest are the displacement and velocity. These are determined by the acceleration and are what you would be computing after 1 ms.
we have :
[tex]v = a t + v_0[/tex]
And
[tex]d = \frac 1 2 a t^2 + v_0 t + d_0[/tex]
where
v = velocity
[itex]v_0[/itex] = initial velocity
d = distance traveled
[itex]d_0[/itex] = initial displacement
a is the acceleration.
t is the time. (here is where your 1ms comes in)
another point, to avoid round off errors do not take steps in multiples of .1 use nice computer friendly steps like [itex]2^{-n}[/itex] where n defines the step of your choice.
Where did you get the 55m displacement? 50 is the correct answer. Perhaps you should share with us more of what you are doing.
Hey Poposhka there are not as many dumb questions as dumb answers, so don't worry about asking. That is how we learn - hopefully.
Yes but since it is per second squared, then it is 10^-6 per millisecond squared
Actually i think i have a fundamental flaw in my understanding here... let's backtrack for a second...
Since 1 Newton is the force required to accelerate a mass of 1 kg at a rate of 1 m/s/s (or m/s^2). Does that mean that a increases by 1 each second?
So at t=0, a=0, t=1 a=1, t=2 a=2, t=3 a=3?? or should i look back at Newton's 3rd that states F = m*a, meaning that a is always 1 ( since F = 1, m = 1 )?
Say you have a tiny spaceship with the mass of 1 kg, and a rocket booster producing thrust of 1 N, will the acceleration be a constant 1?
No. If an object has an acceleration of 1 m/s^2, that means its velocity increases by 1 m/s each second.
If a net force of 1 N is exerted on a mass of 1 kg, then its acceleration will be 1 m/s^2. As long as the net force and mass do not change, the acceleration will remain constant.
Not having plugged in the numbers, I don't know how you got 50.01. But using Integrals' equations in incremental steps, you have v(i)=at + v(i-1), or v(i) = 10^-6 meters per millisecond + v(i-1). This makes your velocity v(i) at any time (since v(0) = 0) = i*10^-6 meters per millisecond or i*10^-3 meters per second, which is what you would expect since there are 10^4 increments of milliseconds (10^4*10^-3 = 10). The distance traveled during any increment is d(i) = 0.5at^2 + v(i)t +d(0), or d(i) = (0.5 + i)*10^-6 meters. When summed over 10^4 increments, this equals 50 meters.
here's how i got 55 m from my original statement...
t= 0.00, d= 0.00, v= 0.00, a= 1.00
t= 1.00, d= 1.00, v= 1.00, a= 1.00
t= 2.00, d= 3.00, v= 2.00, a= 1.00
t= 3.00, d= 6.00, v= 3.00, a= 1.00
t= 4.00, d= 10.00, v= 4.00, a= 1.00
t= 5.00, d= 15.00, v= 5.00, a= 1.00
t= 6.00, d= 21.00, v= 6.00, a= 1.00
t= 7.00, d= 28.00, v= 7.00, a= 1.00
t= 8.00, d= 36.00, v= 8.00, a= 1.00
t= 9.00, d= 45.00, v= 9.00, a= 1.00
t= 10.00, d= 55.00, v= 10.00, a= 1.00
[edit] .. hmm should d be calculated before v?? .. let me try [edit2] no go
These values are incorrect. For example:
t= 1.00, d= 0.50, v= 1.00, a= 1.00
To find the distance at any time (starting from 0 at t = 0), use:
[tex]d = 1/2 a t^2[/tex]
(As Integral explained.)
How are you calculating your values?
aah i think i know what the problem is here ...let me investigate
... :smile:
Poposhka said:
If an object travels at 1 m/s through space, would that object not have traveled 1 meter when t=1?
If it traveled at a constant speed of 1 m/s then it will travel 1 m each second. But you are talking about accelerated motion, so speed is not constant.
according to the formula it's
d = 0.5 * 1 * 1 = 0.5
That's the proper way to handle accelerated motion.
Here's how to understand this: In the first second, you go from a speed of 0 to 1 m/s. The average speed during that 1 second interval is 0.5 m/s, so the distance traveled is (0.5 m/s)*(1 s) = 0.5 m.
Ok i think i figured it out, Thanks Al, i gathered that, when i posted that last note, and realized my error.. see what you think of this.
It's in C code, but i'll simplify it so that it might make sense... the sequence of operation goes from top to bottom.
F = 1
m = 1
d = 0
a = F/m
t = 0
v = 0
while ( t <= 10 )
d = d + (0.5 * (v + v + a) )
v = v + a
t = t + 1
Ok let me try and explain unless it makes sense
the symbols used are all in SI and F (force), m (mass), d (distance), a (Acceleration), t ( time ), v (velocity)
the "while" blurb is a "loop" that will execute the operations below the '{' and above the '}' as long as t is equal or less than 10.
inside the { and }, you see 3 statements
the first statement d = d + (0.5 * (v + v + a) ) says that distance changes by the average of the velocity.
the second statement v = v + a says that velocity changes by acceleration
the third statement simply increases time by 1 second.
This seems correct to me, and plugging the numbers in the distance formula gives me the same results... let me experiment with milliseconds now
Gives you the same results as what? This looks correct to me. (Of course, you'll need to modify the code if your interval is milliseconds.)
Any reason why you are writing code to calculate distance second by second, when the same formula gives you the final answer in one step?
Please read my post #3. Your method is not clear. You are adding velocity and acceleration to get a distance. Since velocity and acceleration do not have the same units you cannot add them without some conversion factor. Look post #3 notice that velocity is the result of multiplying acceleration and time. To do your addition you are making a hidden multiplication factor of 1 s. Thus your difficulty with other sized steps.
If you use the relationships I gave you in #3 you will not need to compute intermediate steps. You can compute for ANY time t.
If you were to continue with the same algorithm and chose a step of .1 you would see serious numerical errors in a pretty short time. DO NOT take additive steps of .1 (or any multiple of .1 which is not a multiple of .5) These numbers cannot be precisely represented in a computer.
If you feel you must take a step of .1 then use an integer counter and do a multiplication by the step size to get your "position". This way the round off error does not accumulate.
  • · Replies 16 ·
  • · Replies 30 ·
