Socket Confirmation: Java Security Checks Needed?
  • Thread starter Thread starter 0rthodontist
    Socket
The discussion centers on ensuring security in a Java application that communicates via sockets. The user seeks to confirm whether checking the IP address alone is sufficient to verify the authenticity of the connecting application or if additional security measures are necessary. Currently, the application employs a method of passing a random integer for verification. The consensus indicates that relying solely on IP address checks is inadequate due to the potential for IP spoofing, and implementing additional security checks is essential for robust protection.
  • Understanding of Java socket programming
  • Knowledge of network security principles
  • Familiarity with IP address spoofing techniques
  • Experience with secure communication protocols
  • Implement Java Secure Socket Extension (JSSE) for enhanced security
  • Research methods for validating application identity using cryptographic techniques
  • Explore the use of Transport Layer Security (TLS) in Java applications
  • Learn about secure random number generation in Java for verification processes
Java developers, security engineers, and anyone involved in building secure networked applications will benefit from this discussion.
0rthodontist
I have a Java application that takes an action when another application starts and connects to it via a socket. The thing is that I only want the original application to take the action when the other application is on the local host. I check the IP address of the socket to confirm this, but could someone spoof the IP address of a Java socket? Or does Java automatically do some two-way checking? Right now it is set up so that the original program passes a random integer back and forth to confirm that the other program is where it says it is, but do I actually need to do this?
  • · Replies 39 ·
  • · Replies 40 ·
13K
  • · Replies 33 ·
