Complicated trigonometry problem
  • Thread starter Thread starter Natasha1
    Trigonometry
The discussion centers on solving a complicated trigonometry problem involving angles and distances between points in a geometric configuration. Key points include the identification of angles at points 6, 7, and 8, each measuring 120 degrees, and the calculation of distances using the sine and cosine rules. The total length of the shortest path calculated is approximately 3.891155 cm. The problem also highlights a discrepancy in the visual representation of the hexagon, prompting a request for clarification on the connections between points.
  • Understanding of basic trigonometric principles, including the sine and cosine rules.
  • Familiarity with geometric shapes, particularly triangles and quadrilaterals.
  • Knowledge of angle measurement and properties of isosceles triangles.
  • Ability to interpret geometric diagrams and apply mathematical reasoning to solve problems.
  • Study the sine and cosine rules in depth to enhance problem-solving skills in trigonometry.
  • Learn about the properties of isosceles triangles and their applications in geometric problems.
  • Explore geometric visualization techniques to better understand complex shapes and angles.
  • Investigate methods for calculating distances in polygons, particularly hexagons, to apply to similar problems.
Students studying trigonometry, educators teaching geometry, and anyone involved in solving complex geometric problems or preparing for exams in mathematics.
Natasha1
Could someone check this for me and help answering the questions at the end
The 3 angles around point 6 are 120 degrees each. This is also the case for point 8 which is linked to point 2, 3 and 7.
Now the 3 angles formed by the lines leaving point 7 are also 120 degrees.
If the distance between point 1 and 2, 2 and 3, 3 and 4, 4 and 5 is 1 cm.
5,6,4 forms an isosceles triangle and so does 2,8,3 triangle.
What is the total distance of the lines?
My answer:
Now, let's start by dropping a vertical line segment 1-7 or a. At point 7, we branch into two lines, one of whom is 7-6 or b. From point 6, we branch into 6-5 or c, and 6-4 or d.
Now, segment a bisects the 108o angle at point 1.
Lets call the side 5-1, e.
In quadrilateral abce, angle 6-5-1 = 360 - 54 - 120 - 120 = 66o.
Lets call side 4-5, f.
In triangle cdf,
Angle 6-5-4 = 108 - 66 = 42o.
So, angle 6-4-5 = 180 - 120 - 42 = 18o.
(This triangle therefore is not isosceles.)
Using the sine rule,
f/sin(120o) = c/sin(18o) = d/sin(42o)
Since f = 1 cm,
c = 1*sin(18o)/sin(120o) = 0.356822 cm.
d = 1*sin(42o)/sin(120o) = 0.772645 cm.
Lets call line segment 1-6, g.
In triangle gce,
Using the cosine rule,
g2 = (c)2 + (e)2 - 2(c)(e)cos(66o)
g2 = (0.356822)2 + (1)2 - 2(0.356822)(1)cos(66o)
g = 0.914908 cm
c/sin (angle 5-1-6) = g/sin(66o)
(0.356822)/sin(angle 5-1-6) = (0.914908)/sin(66o)
So, angle 5-1-6 = arcsin[(0.356822)*sin(66o)/(0.914908)] = 20.872561o
In triangle abg,
g = 0.914908 cm.
Angle 6-1-7 = 54 - 20.872561 = 33.127439o
Angle 7-6-1 = 180 - 33.127439 -120 = 26.872561o
(0.914908)/sin(120o) = a/sin(26.872561o) = b/sin(33.127439o)
So,
a = (0.914908)*sin(26.872561deg)/sin(120o) = 0.477521 cm
b = (0.914908)*sin(33.127439deg)/sin(120o) = 0.577350 cm
Therefore, the total length of the shortest way is:
= a + 2 (b + c + d)
= 0.477521 + 2 (0.577350 +0.356822 +0.772645) = 3.891155 cm.
How can I find the total length in the hexagon (see attached picture)
Your description of the problem doesn't seem to match the pictures. For example, I only see one line connected to point 6, not three. And what do you mean by finding the total length of the lines? Are supposed to find the length of every line in the diagram and then add these up? Please try to describe the problem more clearly, and maybe focus only on the parts that are giving you the most trouble.
