integral: square root of tan x
by Jeremy
Tags: integral, root, square
Jeremy
Jeremy is offline
#1
May13-06, 05:11 PM
P: 24
My class, teacher included, cannot seem to figure out the integral of the square root of tan x. Maybe someone here can help?
thanks,
jeremy
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Emieno
Emieno is offline
#2
May13-06, 06:03 PM
P: 112
why don't you volunteer to get acreditted ?
Orion1
Orion1 is offline
#3
May13-06, 11:05 PM
Orion1's Avatar
P: 991
Examine the given references listed in the archive.
Reference:
http://www.physicsforums.com/showthread.php?t=91866
http://www.physicsforums.com/showthread.php?t=83012
arildno
arildno is offline
#4
May14-06, 06:14 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
The simplest way is to set u=sqrt(tan(x)); you'll end up with a rational integrand that you may decompose with partial fractions.
(Remember that sec^2(x)=tan^2(x)+1=u^4+1)
Hootenanny
Hootenanny is offline
#5
May14-06, 06:32 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
This may be a bit simplistic but why can't you simply do;
[tex]\int \sqrt{\tan x} \;\; dx = \int \tan^{\frac{1}{2}}x \;\; dx[/tex]
[tex] = \frac{3}{2}\tan^{\frac{3}{2}} x = \frac{3}{2}\tan x \sqrt{\tan x} [/tex]
~H
arildno
arildno is offline
#6
May14-06, 07:15 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Hmm..because it is wrong perhaps?
(Differentiate your last expression and see if you get your integrand)
arunbg
arunbg is offline
#7
May14-06, 07:30 AM
P: 602
Well Hoot, what you have done is considered tan(x)=u and integrated
u^1/2 du .But you haven't changed dx to du.You can do this as
[tex]u=tan(x)^{\frac{1}{2}}[/tex]
[tex]\frac{du}{dx}=\frac{sec^2(x)}{2\sqrt{tan(x)}}[/tex]
and then find du and so the integrand changes.
Just follow Orion's thread to see how it is done.
We had the exact same question for our final board exams in India.
It took me 10 mins of precious time and two pages of trial to finally get to the answer( a very big one mind you).And to think you did it all for 3 marks in a 100 mark paper.Phew!
PS:Something wrong with latex? I just can't seem to edit them.
PPS:Hoot, even if you are integrating u^(1/2) it would be 2/3u^3/2
Hootenanny
#8
May14-06, 07:35 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Ahh, dammit! I knew it was too simple. It's a repeat of my xmas exams when I did a very similar thing with secant! Sorry guys!
~H
dextercioby
dextercioby is offline
#9
May16-06, 05:22 AM
Sci Advisor
HW Helper
P: 11,863
It's much more interesting to consider
[itex] \int \sqrt{\sin x} \ dx [/itex]
Daniel.
Orion1
Orion1 is offline
#10
May16-06, 07:11 AM
Orion1's Avatar
P: 991
[itex]\int \sqrt{\tan x} \;\; dx = \frac{1}{2 \sqrt{2}} [ 2 \tan^{-1} (1 - \sqrt{2} \sqrt{\tan x} ) + 2 \tan^{-1} ( \sqrt{2} \sqrt{\tan x} + 1 ) + ...[/itex]
[itex]\ln (| - \tan (x) + \sqrt{2} \sqrt{\tan x} - 1 |) - \ln (| \tan x + \sqrt{2} \sqrt{\tan x} + 1 |)][/itex]
Reference:
nrqed
nrqed is offline
#11
May16-06, 12:37 PM
Sci Advisor
HW Helper
P: 2,886
Quote Quote by dextercioby
Daniel.
As helpful as usual...
arildno
arildno is offline
#12
May16-06, 01:13 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Daniel.
What's interesting about the integral:
[tex]\int\frac{2u^{2}du}{\sqrt{1-u^{4}}}[/tex]
Orion1
Orion1 is offline
#13
May16-06, 10:19 PM
Orion1's Avatar
P: 991
Quote Quote by arildo
[tex]\int\frac{2u^{2}du}{\sqrt{1-u^{4}}} = \frac{-2\,{\sqrt{1 - u^2}}\,{\sqrt{1 + u^2}}\,\left( -\text{EllipticE}(\sin^{-1} u,-1) + \text{EllipticF}(\sin^{-1} u,-1) \right) }{{\sqrt{1 - u^4}}}[/tex]
Arildno, what are you suggesting for [tex]u[/tex]?
dx
dx is offline
#14
May17-06, 12:36 AM
HW Helper
PF Gold
dx's Avatar
P: 1,962
while were on the topic of integrating expressions that contain square roots of trigonometric functions, I was having a hard time a while ago evaluating this
[tex]\int{\frac{1}{\sqrt{sin x}}dx[/tex]
Curious3141
Curious3141 is offline
#15
May17-06, 01:20 AM
HW Helper
P: 2,872
Quote Quote by dx
It is always a good idea when confronted with an unfamiliar integral, to verify that it can be done before expending effort to figure out how. Mathematica is a good tool, or you use the free WebMathematica equivalent at http://integrals.wolfram.com/index.jsp
Orion1
Orion1 is offline
#16
May17-06, 01:26 AM
Orion1's Avatar
P: 991
[tex]F(z|m) = \text{EllipticF}[z,m] = \int_0^z \frac{1}{\sqrt{1 - m \sin^2 t}} dt[/tex]
[tex]\int{\frac{1}{\sqrt{\sin x}}dx = \int_0^{\frac{1}{2} \left( \frac{\pi}{2} - x \right)} \frac{1}{\sqrt{1 - 2 \sin^2 t}} dt = -2\text{EllipticF} \left[ \frac{1}{2} \left( \frac{\pi}{2} - x \right), 2 \right][/tex]
Reference:
http://functions.wolfram.com/Ellipti.../EllipticF/02/
arildno
arildno is offline
#17
May17-06, 05:13 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Given a function f with domain D, the function
[tex]G(x)=\int_{x_{0}}^{x}f(y)dy, x_{0}, y, x\in{D}[/tex]
is seen to have no larger domain than f. Since the definite integral can't generate any singularities on its own (integration is a "smoothing" process), it is seen that G doesn't have a less domain than f.
Thus, G has the same domain as f.
Orion1
Orion1 is offline
#18
May17-06, 06:27 AM
Orion1's Avatar
P: 991
Given that [itex]\sqrt{\tan x}[/itex] is valid in Quadrants I,III then the specific domains for this function are:
[tex]D: \left[ 0, \frac{\pi}{2} \right) \; \; \; I[/tex]
[tex]D: \left[ \pi, \frac{3 \pi}{2} \right) \; \; \; III[/tex]
The third equation component in post #10 is:
[tex]\ln ( - \tan x + \sqrt{2} \sqrt{\tan x} - 1 )[/tex]
Placing the component in a point within its own domain produces:
[tex]\ln \left( - \tan \frac{\pi}{4} + \sqrt{2} \sqrt{\tan \frac{\pi}{4}} - 1 \right) = \ln ( - 1 + \sqrt{2} \sqrt{1} - 1) = \ln ( \sqrt{2} - 2)[/tex]
Taking the 'sign' of internal component [itex]\ln [sgn(\sqrt{2} - 2)][/itex] yields:
[tex]\ln (-1)[/tex]
Reference:
http://mathworld.wolfram.com/Singularity.html
http://www.physicsforums.com/showpos...7&postcount=10
Register to reply
Related Discussions
[SOLVED] Re: Integral involving square root of e^x Calculus & Beyond Homework 6
one integral (square root and gaussian peak) Calculus 13
complex contour integral of square-root Calculus & Beyond Homework 1
Integral with square root Introductory Physics Homework 13
Square root of i General Math 17
