What is the original frequency and how can it be calculated?
The discussion revolves around two problems related to wave phenomena: one involving the frequency of a tuning fork and the other concerning wave properties observed on a beach. The first problem focuses on determining the original frequency of an unknown tuning fork based on beat frequency, while the second problem involves calculating the period, wavelength, and speed of waves crashing onto the beach.
  • Participants explore the relationship between beat frequency and the original frequency of the tuning fork, questioning how the addition of weight affects the frequency. They also discuss the calculations needed for wave properties, including period and wavelength, while considering the relationship between wave speed, frequency, and wavelength.
There is an active exploration of the problems, with participants raising questions about the implications of the beat frequency and the effects of weight on the tuning fork's frequency. Some participants suggest using hints provided by others to guide their reasoning.
Participants note potential issues with punctuation in the problem statements, which may affect clarity. There is also a mention of the original problem being similar to one given by a teacher, indicating a shared context among participants.
Alain12345
I need help with a couple of problems:
A tuning fork of uknown frequency is sounded together with another tuning fork of 630 Hz. Seven beats are noted when a weight is put on the uknown tuning fork. The beat frequency is noted to increase. What is the original frequency?
A cottager lying on a beach notes that in a span of 12 minutes, 57 waves crash onto the beach. She also notes that as one crest is crashing on the beach another crest is passing a boat 10m away. If there are five more crests between the two noted crests, calculate the period, wavelength, and speed of the wave.
Thanks.
So what are the two possible frequencies of the unknown tuning fork? If you put a weight on the end of the tuning fork does the frequency go up or down? That will tell you which of the two possible frequencies is the correct one.
What is the period or 1/f of the wave? How many wavelengths are there in the 10 m. distance? What is the wavelength. What is the relationship between [itex]v, f and \lambda[/itex]?
AM
I think first you need to sort out your punctuations.The question should have read:
A tuning fork of unknown frequency is sounded together with another tuning fork of 630 Hz. Seven beats are noted .When a weight is put on the uknown tuning fork, the beat frequency is noted to increase. What is the original frequency?
Try to use Andrew's hints.
lol I just typed out the same problem that the teacher gave me.
  • · Replies 43 ·
