Can CO2-V Network Solid Be Stabilized at Normal Temperature and Pressure?
  • Thread starter Thread starter bomba923
    Structure
The discussion revolves around the possibility of stabilizing a network solid composed of CO2 molecules, referred to as CO2-V, at normal temperature and pressure (NTP). Participants explore the theoretical implications, structural characteristics, and potential applications of such a material, while addressing the challenges associated with its formation.
  • Some participants suggest that CO2 could form a network solid analogous to SiO2, questioning whether such a structure exists and what it might be called.
  • Others argue that CO2 is typically a gas at NTP and that a network solid cannot form under these conditions, citing the smaller covalent radius of carbon compared to silicon and the higher polarity of CO2.
  • A few participants mention that while CO2 cannot form a network solid at NTP, there are indications that a CO2 network solid has been synthesized under high pressure.
  • One participant introduces the concept of electron shells, suggesting that the presence of intermediate electron d shells in silicon allows for more stable compound formation compared to carbon.
  • There is a discussion about the potential applications of CO2-V if it could be stabilized at ambient conditions, including uses in high-strength materials and optical technologies.
  • A later reply emphasizes that the stabilization of high-pressure phases at lower temperatures is a challenging area of research, noting the need for rare reaction pathways to achieve this.
Participants generally disagree on the feasibility of stabilizing CO2-V at NTP, with some asserting it is impossible while others suggest it may be achievable under specific conditions. The discussion remains unresolved regarding the exact nature and potential of CO2-V.
The discussion highlights limitations related to the definitions of network solids and the conditions required for their formation. There is also uncertainty regarding the existence of reaction pathways that could facilitate the stabilization of CO2-V.
bomba923
Well, we know how quartz and glass are a network SiO2 molecules
*But what if we replace the Si atoms with carbon? In other words, what if we have the same network arrangement of CO2 molecules?
-Is there a name for this network solid?
Edit:
Perhaps I am referring to "CO2-V", possibly?
Chemistry news on Phys.org
I don't think I know what you are asking.
CO2 is a gas, unless its quite cold.
Then it's usually called dry ice.
I am not referring to dry ice~
Dry ice is a molecular solid; I'm referring to a network solid,
with molecular units CO2, just as quartz/glass is SiO2.
http://www.btinternet.com/~chemistry.diagrams/SIO2-3UN.GIF (<-click on the link)
The red spheres represent the oxygen atoms,
and the cyan spheres represent carbon atoms.
~Possibly, I may be referring to CO2-V,
(see http://www.llnl.gov/str/Yoo.html)
but I am not sure...
The network solid you describe does not exist at NTP. The reasons for this are the smaller covalent radius of C (compared to Si, which is large enough to accommodate O-atoms in tetrahedral voids) and the higher polarity of CO2 compared to SiO2.
At very high pressures though, I believe some kind of CO2 network solid has been made.
CO2 won't form a network solid no. C will in the form of coal or diamond and such but you can't compact a gas to form glass
Not under NTP, as Gokul mentioned. But under large pressures...
it has been done (according to the linked article).
Electron shells
The reason that CO2 will not form the network solid as iwould silicon or even sulphur is due to the intermediate electron d shell that is present in these but not in carbon. this shell allows silicon to fulfill more energy states and form a more stable compound. but it does prevent it from forming long chain molecule as carbon will, i.e. dodecane
oh wow that had not been brought to my attention until just now
that's quite useful info, thank you :smile:
[PLAIN said:
http://www.llnl.gov/str/Yoo.html][/PLAIN]
Stabilizing CO2-V
If this new, very hard CO2-V can be stabilized at ambient temperatures and pressures, it will have many uses. (...etc ...etc) New classes of high explosives, nonlinear optical materials with high thermal and mechanical stability, high-strength glass, and superhard materials for tools are all candidates. Crystals that can double the frequency of laser light from infrared to green would be valuable for Livermore's inertial confinement fusion energy program (...etc ...etc)
Hmm...
so can CO2-V be stabilized at all (at NTP) ?? :bugeye:
(CO2-V being the "quartzlike" CO2 I mentioned earlier)
bomba923 said:
Hmm...
That's probably a question that can only be answered by researchers in the field.
What is well-known is that it has become almost commonplace to be able to stabilize high temperature phases of diffferent systems at well below their equilibrium phase transition temperatures. There hasn't been as much success with stabilizing high pressure phases. This particular phase, the CO2-V is a high temperature and high pressure phase.
It will take the discovery of a truly rare and well-hidden reaction pathway that cuts through the giant activation energies needed to reach the phase in question. Does such a pathway exist? No idea.
27K
