Amount of ATP required in photosynthesis.
  • Thread starter Thread starter wasteofo2
    Photosynthesis
The discussion centers around the amount of ATP required in the process of photosynthesis, specifically focusing on the carbon-fixation cycle and the overall reactions involved. Participants explore the relationship between ATP production and consumption, as well as the efficiency of the process.
  • Some participants question how many ATP molecules are used in photosynthesis, with initial confusion regarding the role of ATP in aerobic respiration.
  • It is noted that three ATP and two NADPH are consumed for each CO2 molecule fixed in the carbon-fixation cycle.
  • One participant recalls that 11 photons are required for one sugar molecule, suggesting a thermodynamic efficiency of under 30% for the process.
  • Another participant provides a detailed net reaction for carbon-fixation, indicating that 9 ATP and 6 NADPH are used to produce glyceraldehyde 3-phosphate.
  • There is mention of the need for 6 turns of the Calvin cycle to produce one glucose molecule, which requires 18 ATP in total.
  • Some participants clarify that photosynthesis produces glucose rather than ATP directly, leading to further discussion about the overall reaction and intermediate steps involved.
  • One participant expresses uncertainty about the ATP required for converting glyceraldehyde 3-phosphate to glucose 1-phosphate.
  • Another participant emphasizes that photosynthesis occurs in discrete steps, providing a breakdown of the dark reaction involving 18 ATP and 12 NADPH.
  • Finally, a participant confirms that 18 ATP molecules are produced per glucose molecule, summarizing the discussion.
Participants express differing views on the specifics of ATP usage in photosynthesis, with some agreeing on certain figures while others challenge or refine those claims. The discussion remains unresolved regarding the exact amount of ATP used in the overall process and the efficiency of photosynthesis.
There are limitations in the discussion regarding missing assumptions about the definitions of terms used, as well as unresolved mathematical steps related to the ATP calculations. The scope of the discussion also varies, with some participants focusing on the overall reaction while others delve into intermediate steps.
wasteofo2
Does anyone know how many ATP molecules are used in the process of photosynthesis? I think with aerobic respiration 2 are used, but I could be wrong.
Biology news on Phys.org
ATP required in photosynthesis? ATP is produced during photosynthesis, so I guess you are referring to the carbon-fixation cycle?
Three molecules of ATP and two molecules of NADPH are consumed for each CO2 molecule that is fixed.
So how much ATP and NADPH is produced out of every quantum of light?
I seem to recall that 11 photons are required for one sugar molecule, which is later used by the cell to make other molecules. The point of what I was reading was that 3 photons would be 100% thermodynamic efficiency, so the actual process is a little under 30% efficient. This was long ago (~20 years) so maybe understanding has changed.
Yes, my answer was incomplete, since the net reaction of carbon-fixation is:
[itex]3CO_2+9ATP+6NADPH+H_2O\rightarrow[/itex]
[itex]glyceraldehyde3phosphate+8P_i+9ADP+6NADP^+[/itex]
So this glyceraldehyde then can be the substrate for glucose prodcution.
Each turn of the light independent cycle (calvin-benson) requires 1 CO2, 3 ATP, and 2 NADPH. It needs 6 turns of the cycle to make 1 molecule of glucose because glucose has a 6 carbon atom backbone.
Aerobic respiration needs 2 ATP to start reactions and when completed will have a net yield of 36 ATP
You are partially right, I think.
This reaction takes place in the chloroplast:
After which the glyceraldehyde 3-phosphate is exported into the cytosol, where it can be converted into fructose 6-phosphate and glucose 1-phosphate. The glucose 1-phosphate is then converted to the sugar nucleotide UDP-glycose, and this combines with the fructose 6-phosphate to form sucrose phosphate, the immediate precursor of the disaccharide sucrose (which the plant uses for energy).
I am not sure how much ATP is required to go from glyceraldehyde 3-phosphate to glycose 1-phosphate.
Monique, you over complicated the question a bit. Firstly, photosynthesis doesn't make ATP, it makes [itex]C_6H_1_2O_6[/itex]
I wanted to know how many ATP molecules are used in the overall reaction of photosynthesis.
[itex]12H_2O+6CO_2+Light Energy\rightarrow<br /> C_6H_1_2O_6+6O_2+6H_2O[/itex]
I thought that
[itex]C_6H_1_2O_6+6O_2\rightarrow<br /> 36ATP+6CO_2+6H_2O[/itex]
Used 2 molecules of ATP in the process...
Ok, but photosynthesis occurs in discrete steps, I was considering those. What you are giving is a net reaction, there are intermediate steps.
6 CO2 + 18 ATP + 12 NADPH = C6H12O6 + 18 (ADP + Pi) + 12 NADP+
There you go: the dark reaction of photosynthesis :)
The light reaction takes 6 H2O and turns it into 6 O2.
12 NADP+ gets reduced to 12 NADPH and H+ during the reaction.
The H+ gradient is used to make 18 ATPs, which go into the dark reaction.
Alright, 18 ATP moledules per glucose molecule, thanks.
  • · Replies 18 ·
15K
