Thermodynamic - conservation of energy/mass problem, I can't figure it out
The discussion revolves around the collision of an antimatter proton and a normal matter proton, both traveling at approximately 3/4 the speed of light. Participants explore the implications of energy conservation during the collision, the fate of the energy propelling the particles, and the concepts of mass in relativistic physics.
  • One participant questions where the energy goes upon the collision of an antimatter proton and a normal matter proton, considering various possibilities such as conversion to energy, heat, or potential violations of thermodynamics.
  • Another participant asserts that when particles and antiparticles annihilate, high-energy photons are released, and the energy of these photons should equal the initial energy of the particles, emphasizing that energy is conserved.
  • A different participant states that the concept of "mass" is irrelevant to the problem, focusing instead on the conservation of energy and momentum during annihilation.
  • There is a discussion on the distinction between invariant mass and relativistic mass, with one participant explaining that invariant mass is independent of velocity while relativistic mass increases with velocity.
  • One participant expresses a desire for further clarification on the concept of invariant mass, indicating a need for more information on the topic.
  • Another participant provides a resource link to a FAQ on mass in relativity, explaining the definitions and differences between relativistic mass and invariant mass.
Participants generally agree on the conservation of energy principle during the annihilation of particles. However, there are multiple competing views regarding the interpretation of mass and its relevance to the problem, indicating that the discussion remains unresolved in certain aspects.
The discussion includes limitations in understanding the implications of mass definitions and the conditions under which energy conservation applies, with some participants expressing uncertainty about specific concepts.
BrianConlee
Ok, I was trying to think of a first problem/question to pose to everyone for my first pose, so here it goes...
(there's a lot of questions and topics already posted, so someone may have already asked this)
Situation:
One Antimatter Proton and One normal matter proton are on a collision coarse. Each one is traveling at about 3/4 the speed of light.
Upon collision, where does the energy that was propelling the atoms go?
Was their increased mass due to their speed forced into the 2nd matter to energy conversion? (the first being the initial force to mass) Was it merely expelled as heat in some form of friction? Or did it violate thermodynamics?
It's probably an easy answer.
Brian
(there's a lot of questions and topics already posted, so someone may have already asked this)Situation:
Was their increased mass due to their speed forced into the 2nd matter to energy conversion? (the first being the initial force to mass) Was it merely expelled as heat in some form of friction? Or did it violate thermodynamics?It's probably an easy answer.
Brian
When particles and antiparticles annihilate, high-energy photons are released (I think it's always two photons, but I'm not sure). From the point of view of any inertial frame, the energy of the photons after the collision should equal the energy of the particle and antiparticle beforehand.
Also, it doesn't really make sense say that any energy was needed to "propel" the particles, since objects in motion naturally tend to continue moving at constant velocity, it takes an application of energy to change their velocity. The energy of a given particle does increase in your frame as its velocity in your frame increases (according to the formula [tex]E^2 = m^2 * c^4 + p^2 * c^2[/tex], where p is the relativistic momentum [tex]mv/\sqrt{1 - v^2/c^2}[/tex]), but it's not as if energy is being expended to keep the particle moving.
Brian
It's an easy answer. Energy is conserved. You don't even have to know (or care) what the "mass" of the particles involved is. All that is important as far as working the problem goes is the energy of the particles.
The important thing is that the particles initally had some energy, and that when they annhilate, energy (and momentum) must both be conserved. Therfore the energy of the two particles after annhilation is the same as the energy of the particles before annhilation.
ps - while the "mass" of the particles increases if one uses "relativistic mass", the mass does not increase if one uses the more modern "invariant mass". However, the key point is really that mass is totally irrelevant to this problem.
You do however need to know the formula for the energy of a particle moving at a specified velocity v. That formula is:
[tex]E = m_0 c^2/ \sqrt{1 - v^2 / c^2}[/tex]
People who use invariant mass (as I do) will frequently write m instead of [itex]m_0[/itex] in the above formula.
Regardless of how it is written, the [itex]m_0[/itex] in this equation is the invariant mass of the particle which is sometimes called the 'rest mass'.
Hey,
thanks for the reply. I think this forum is a godsend. Can you tell me more about invariant mass. I must admit it is a new concept.
Brian
I'd suggest reading the sci.physics.faq :
http://math.ucr.edu/home/baez/physics/Relativity/SR/mass.html"
Does mass change with velocity?
There is sometimes confusion surrounding the subject of mass in relativity. This is because there are two separate uses of the term. Sometimes people say "mass" when they mean "relativistic mass", mr but at other times they say "mass" when they mean "invariant mass", m0. These two meanings are not the same. The invariant mass of a particle is independent of its velocity v, whereas relativistic mass increases with velocity and tends to infinity as the velocity approaches the speed of light c. They can be defined as follows:
mr = E/c^2
m0 = sqrt(E^2/c^4 - p^2/c^2)
where E is energy, p is momentum and c is the speed of light in a vacuum. The velocity dependent relation between the two is
mr = m0 /sqrt(1 - v^2/c^2)
This is just the bare-bones of the FAQ, there is more information there.
The reason I prefer invariant mass for use with special relativity is that the mass of an isolated system is the same for all observers, the invariant mass does not depend on the coordinate system used (i.e. the velocity of the mass relative to the observer).
This is not the case for "relativistic mass" - here the mass depends on the observer (what coordinate system is used, the velocity of the mass with respect to the observer).
Thus invariant mass IMO best meets the original intent of mass, which is a "measure of the quantity of matter".
  • · Replies 77 ·
  • · Replies 18 ·
  • · Replies 130 ·
18K
  • · Replies 44 ·
