Calculating Water Splash Depth of Wooden Ball
  • Context: Undergrad
  • Thread starter Thread starter shak
    Depth Water
The discussion revolves around calculating the depth to which a wooden ball will sink after being dropped into still water from a height of 1 meter. Participants explore the dynamics of the splash, buoyancy forces, and the effects of drag on the ball's motion through the water. The conversation includes theoretical considerations and practical challenges in deriving a formula for this scenario.
  • One participant suggests using conservation of energy to relate the kinetic energy of the ball and the work done against buoyancy forces.
  • Another participant notes the complexity introduced by drag forces and the potential for turbulent flow as the ball enters the water.
  • A participant expresses difficulty in obtaining accurate results using energy conservation, acknowledging the challenges posed by drag and other factors.
  • One participant provides a link to a resource that may offer a good approximation for the problem, emphasizing the need to calculate the initial velocity before impact.
  • A participant expresses frustration with the complexity of the problem, seeking a simpler approach and referencing high-level mathematics related to the displacement of the ball.
Participants do not reach a consensus on a single formula or method for calculating the splash depth, and multiple competing views and approaches remain in the discussion.
Participants highlight limitations in accounting for drag, turbulence, and the initial conditions of the ball's drop, which complicate the derivation of a complete formula.
shak
Hi!
I have a problem.
Say I have a wooden ball, 5 cm in diameter, 40 grams, I drop it from a height of 1 meter into some still water. Obviously, it will splash in and dip a little before buoyancy forces take over and bring it to the surface,
I have never heard of a way, but maybe the pros here know a formula or something,
Is their any way to calculate how deep it will go after the initial splash before the buoyancy forces take over??
Cheers!
Shak
I suppose you could consider a simplified verson using conservation of energy. The kinetic energy of the ball before it impacts the water plus the change in gravitational potential energy, must equal the work done against the buoyancy force.
~H
There is also the complication of the huge drag factor while the ball moves through the water, and the flow will probably be turbulent.
Also the impact at the surface of the water will involve a combination of displacement and drag.
Thanks guys!
I tried using the energy converting from potential into work done, but the figure comes out obviously wrong...I think you're right about the drag and other factors which are hard to account for...
is their a single complete formula for working this out? or could someone please post a quick and dirty formula which may work?
wow! This is getting way over my head, I was expecting something simple like f=ma... :(
I also found this - http://www.owlnet.rice.edu/~phys111/Lab/expt02.pdf (Its a PDF!)
Any chance someone who knows the high level maths of double differentials and cosh functions could solve this for the displacement?
As I have said, the ball, of mass m and diameter r, dropped from rest at a height h, top of water can be at h=0,...I guess at the deepest dip point (h=d), the vertical velocity will be 0 (?) sort of like a vertical pendulum experiment we did in school with a spring and weight at the end...
Anyone?!
Thanks in advance!
  • · Replies 16 ·
  • · Replies 32 ·
14K
