Why Do Solids Expand When Heated?
  • Thread starter Thread starter Amith2006
    Expansion Solids
Solids expand when heated primarily due to the increase in kinetic energy of atoms, which leads to greater atomic vibrations. The discussion highlights the limitations of the harmonic approximation in explaining thermal expansion, as it predicts a zero thermal coefficient of expansion. The presence of anharmonicity, or the asymmetry of the potential energy curve around the equilibrium distance between neighboring atoms, is crucial for accurately modeling this phenomenon. Additionally, some solids exhibit virtually zero thermal expansion coefficients due to nearly parabolic atomic interactions over a range of energies.
  • Understanding of kinetic energy and atomic vibrations
  • Familiarity with the harmonic approximation in solid-state physics
  • Knowledge of potential energy curves and their significance in atomic interactions
  • Basic concepts of thermal expansion and its measurement
  • Research anharmonicity in solid-state physics
  • Study the implications of the harmonic approximation on thermal properties
  • Explore materials with zero thermal expansion coefficients
  • Learn about potential energy curves and their role in atomic interactions
Students and professionals in materials science, physicists studying solid-state phenomena, and engineers focused on thermal properties of materials.
Amith2006
Sir,
Why does solid expand on heating?
The answer to this question given in my book is “The potential energy curve is asymmetric about the equilibrium distance between neighbouring atoms. Is it right?
I think solid expands due to increase in kinetic energy of atoms.
Amith2006 said:
Sir,
Yes it is. The most eggregious flaw of the harmonic approximation to the treatment of solids is that it leads to zero thermal coefficient of expansion. Without anharmonicity (or asymmetry, or deviation from purely quadratic interaction terms), you can't solve this problem.
The classical oscillator turning points are separated by distances smaller than typical interatomic spacings. In the harmonic approximation, it's possible to make atoms oscillate much faster (irrespective of phase differences) about their mean positions, without having to change the distance between these mean positions. Alternatively, one can see that with a symmetric potential, no matter what the energy (and hence turning points), the mean position is always that of the minimum.
Now there are a few solids with virtually zero thermal expansion coefficient. These are solids where the interaction between atoms is almost exactly parabolic over a significant range of energies.
Edit : Look here for a picture - http://www.mse.uiuc.edu/info/mse182/t79.html
  • · Replies 33 ·
  • · Replies 19 ·
