Maximum Pressure over a Reaction
The discussion revolves around the maximum pressure achievable during an exothermic reaction that evolves gas, specifically focusing on the reaction between aluminum and water to form aluminum hydroxide and hydrogen gas. Participants explore the thermodynamic implications of pressure on reaction rates and the calculations involved in determining maximum pressure under specific conditions.
  • One participant presents a calculation for maximum pressure based on the work done to expand gas and the change in enthalpy, arriving at approximately 612 atm, but expresses doubt about the accuracy of this result.
  • Another participant suggests using Gibbs Free Energy to find equilibrium pressure, prompting further exploration of thermodynamic values.
  • Participants discuss the difficulty in obtaining the free energy of formation for aluminum hydroxide, with one participant estimating it based on available data for related compounds.
  • A later reply provides a source for the free energy of formation, leading to a revised calculation of maximum pressure around 642 atm, though the participant questions the reasonableness of this figure based on observed reaction rates.
  • Concerns are raised about the distinction between chemical kinetics and thermodynamics, with a suggestion that practical observations contradict the theoretical calculations of high pressure.
Participants do not reach a consensus on the maximum pressure achievable or the validity of the calculations presented. There are competing views regarding the relationship between pressure and reaction rates, and the discussion remains unresolved.
Participants note limitations in available thermodynamic data, particularly for aluminum hydroxide, which affects the accuracy of their calculations. There is also an acknowledgment of the complexities involved in relating thermodynamic predictions to observed reaction behavior.
This discussion may be of interest to those studying thermodynamics, chemical kinetics, or anyone involved in reactions that produce gases under varying pressure conditions.
mrjeffy321
I have an exothermic reaction which evolves gas. The change in entropy of the reaction is -837.02 kJ per 3 moles of gas evolved (about -279 kJ/mol). The reaction takes place inside a sealed container with a constant volume [say volume = 4.5 E-3 m3]. We will assume the temperature of the reaction to be a constant 80° C (far hotter than the temperature outside the container) so as to prevent heat energy flowing into the system from the surroundings.
As the reaction proceeds, the gas evolved must be expanded into the atmosphere above at an ever increasing pressure…a process which takes energy. If we assume all the energy comes from the ambient heat inside the system (which in term comes from the change in enthalpy of the reaction), as the pressure above the reaction grows, eventually the rate of reaction will drop to zero (reaction will stop) since it would take more energy than is released in order to expand the gas.
I am trying to solve for the maximum pressure at which the reaction will still take place.
The work done by the system to expand the gas is equal to,
W = ∆P * V
The point at which the reaction would stop would be when the work to expand the gas equals the change in enthalpy of the reaction.
∆H = ∆P * V
279000 Joules = ∆P * (4.5 E-3 Liters),
∆P = 6.2 E7 Pa ~= 612 atm
This would mean that the reaction would proceed until the “atmospheric” pressure was greater than or equal to about 612 atmospheres!
This is an extremely high pressure, far greater than what I would expect, which leads me to believe I made an error on one of the steps.
Does anyone see where I might have gone wrong?
You're looking for equilibrium pressure over a reaction. Use Gibbs.
Gibbs Free Energy? OK.
The problem now is that I cannot find the Free energy of formation or the entropy of formation for one of my products of the reaction,
Aluminum Hydroxide, Al(OH)3.
Without this value, all I can do is estimate the actual change in free energy of the reaction. Based on the values I could find of AlCl3 (-628.8 kJ) and Al2O3 (-1582.3 kJ), I figure Al(OH)3 should be somewhere around -1000 kJ/mol.
If this is true, then the change in free energy of the reaction would be somewhere around -577.22 kJ. If I then follow my previous previous process, I would get a pressure of around 4.3 E7 Pa as the max pressure, only slightly less.
Does anyone know the free energy of formation of Aluminum Hydroxide, Al(OH)3 ?
NIST webbook only seems to have the standard enthalpy of formation of Al(OH)3, not the entropy of free energy value.
I checked my 2000-2001 CRC handbook and there is no entry for Aluminum Hydroxide.
Did you try searching on google? I'm sure it's floating around out there somewhere.
Yes, of course I tried google as well, but no luck on my first few attemps the other day.
I was able to find a figure which looks reasonable on this site,
http://www.geo.cornell.edu/geology/classes/geo321/Weathering_notes_05.pdf
Gf° = -1151 kJ/mol
which is pretty close to the estimate I made earlier up. Using this figure, I get an over all change in free energy from the reaction of -293.07 kJ/mole of gas produced. This would give me a max pressure of about 6.5 E7 Pa or about 642 atm.
Does this seem like a reasonable answer?
What's the reaction?
The specific reaction I am dealing with is,
2 Al(s) + 6 H2O(l) --> 2 Al(OH)3(s) + 3 H2(g)
The reason I am not very confident of my answer of some 600 or so atmospheres of pressure is that in practice, I have noticed an appearent drop on the rate of the reaction when even a slight pressure is allowed to accumulate over the reaction.
I know I am not getting it anywhere near 600 atm (otherwise I would not be hear writting this), but it atleast seems like the reactions slows down a lot when the Hydrogen gas produced is allowed to build up pressure inside the reaction vessel.
First, you need to make the distinction between chemical kinetics and thermodynamics; second, you need to state a complete thermodynamic description of the system before trying to do an analysis. Six hundred atmospheres? If hydrogen reduction of aluminum oxide were easy, Alcoa and Reynolds wouldn't be buying, or synthesizing cryolite for electrolysis cells.
15K
