Why Does Switch Size Depend on Stored Energy & Inductance?
  • Thread starter Thread starter cabellos
    Switch
The size of a switch is determined by the stored energy it must interrupt and the inductance of the connected circuit. When disconnecting a switch, the proximity of the circuit sides allows for potential arcing, which is detrimental. Inductance can exacerbate this issue, as the collapsing magnetic field generates a voltage spike that increases the risk of arcing. Switch sizes are specifically designed based on their interrupt capacity to safely disconnect without causing arcing, employing various protection methods such as magnetic polarization and air blasting.
  • Understanding of electrical circuits and switch operation
  • Knowledge of inductance and its effects on voltage
  • Familiarity with arcing phenomena in electrical systems
  • Awareness of protective measures for electrical components
  • Research the principles of inductance and voltage spikes in circuits
  • Learn about switch interrupt capacity and sizing guidelines
  • Explore protective methods against arcing, including magnetic and air-blasting techniques
  • Investigate the use of diodes in preventing voltage spikes in inductive circuits
Electrical engineers, circuit designers, and anyone involved in the design and safety of electrical switching systems will benefit from this discussion.
cabellos
Why is the size of a switch determined by the stored energy that is to be interupted and by the inductance of the circuit it is connected to?
thanks,
Phil
When you disconnect a switch in a circuit of a given potential, it has the ability to transmit current directly through the air towards the nearest part of the switch. Since the switch is a conductive disconnecting device, the two sides of the circuit are in very close proximity to each other initially at the first point of disconnection, (over time, they obviously become further spread apart), and it is very easy for electric current to "arc" to the other side of the switch. Arcing is bad.
In the case of inductance, if no diode is placed parallel with the coil, the collapsing magnetic field of the inductor causes a voltage spike in the circuit (Its direction dependent on the fields polarity). That spike means the voltage is now higher than the source voltage and it is much easier to arc again to the other side of the switch, and at farther distances.
Switch sizes are based on their interrupt capacity. What they can safely disconnect without arcing. There are many protection methods employed. Magnetics the polarize the air against conduction of electricity, air blasting to disorganize ionized air particles for the same reason (corona voltage), mylar barriers, etc etc.
I hope this helps :)
Suer
  • · Replies 19 ·
  • · Replies 18 ·
