Separating Ethanol from Water by Boiling
  • Thread starter Thread starter Telmerk
    Boiling
The discussion revolves around the feasibility of separating ethanol from water through boiling, including considerations of azeotropes, boiling points, and methods for achieving desired purity in mixtures. Participants explore both theoretical and practical aspects of the separation process.
  • Experimental/applied
  • Some participants propose that boiling the mixture at around 80°C could allow for the evaporation of ethanol before water, but question whether complete separation is achievable.
  • One participant calculates the energy required to boil a specific mass of ethanol and suggests that it could be done quickly with sufficient power.
  • Concerns are raised about the potential for flammability when boiling ethanol vapors.
  • Azeotropes are introduced as a complicating factor, with one participant noting that the ethanol-water azeotrope consists of approximately 95% ethanol and 5% water, complicating the goal of obtaining pure ethanol or water.
  • Another participant expresses a desire to obtain pure water from a low concentration ethanol mixture, emphasizing that they do not care about the ethanol's fate.
  • Methods for determining the purity of the resulting mixture, such as measuring the refractive index, are discussed, with considerations about how particles in the mixture may affect measurements.
  • Some participants suggest alternative methods for obtaining pure components, such as reverse osmosis or distillation, but the practicality of these methods is questioned.
Participants express a range of views on the effectiveness of boiling for separation, with some acknowledging the limitations imposed by azeotropes and others exploring different methods and conditions for achieving their goals. The discussion remains unresolved regarding the best approach to achieve complete separation.
Participants note the dependence on specific conditions such as temperature, concentration, and the presence of azeotropes, which may affect the outcomes of boiling and separation efforts.
This discussion may be of interest to those involved in chemistry, chemical engineering, or experimental physics, particularly in the context of separation techniques and mixture analysis.
Telmerk
Hi folks,
This is rather physics... Is it possible, to separate ethanol and water by boiling the ethanol. Will the ethanol go away? Or will there be always a little amount of it in the mixture? :bugeye:
Thanks in advance!
Chemistry news on Phys.org
The ethanol would boil away at around 78 celsius, before the water would boil away (at 100). You could use a distiller or other apparatus to capture the ethanol that evaporates. As for obtainin pure ethanol, I imagine there would always be a littel water no matter what that boils away with the ethanol no mater how times you boiled it.
Thank you, Daveb! My goal is get rid of the ethanol. So it seems that It is possible by simply boiling the mixture at 80C. And I guess that I can calculate the boiling time if I know the boiling heat, the mass of the ethanol, and the power of my heater. I hope so.. :)
I mean:
I have 5ml water, and 1ml ethanol. Question is that how much time do I need to get rid of the ethanol in the system?
Boiling heat of ethanol: Qb=906.07kJ/kg
mass of ethanol: meth=0.789g (If I take a density value 0.789g/cm3 --- ut this is valid at 18oC).
Power of my heater: 400W
So: To boil 1kg ethanol I need 906.7kJ. To boil 0.789g I need only 714J.
So with 400W it takes only a few seconds... :rolleyes:
With 400W it might well catch fire as vapour. Which is another way to get rid of it, I guess...
Yesyes, but this 400W is not not only for hewating up the ethanol-water mixture. there is water bath around. 10l. So my previous calculation was just a first approximation.. :)
Telmerk, are you familiar with azeotropes?
If you want to boil away some of the ethanol why don't you just dilute your mixture with more water?
Edit: Or do you want to boil away all of it? So this is more about the experiment than the results I guess.
Mr. GCT! No, I wasn't until this this moment. :bugeye: Thank you very much for your notification! So I can't separate my water-ethanol mixture theoretically and practically. Azeotrophy means - I hope I looked after well - that the composition is the same in the liquid and in the vapour phase. Bad news. Then what to do? :frown:
Well, if I remember correctly the ethanol-water azeotrope is something around 95% ethanol and 5% water. So if you want to leave pure water behind, it's simple...all you got to do is boil the ethanol-water azeotrope away. You'll be losing some of your water to the azeotrope though. Getting pure ethanol, however, is more difficult and cannot be achieved through simple distillation because you will always be stuck at 95%.
Telmerk, I'm not quite sure why you would want to separate the mixture completely, that is, there are plenty of ways to obtain pure ethanol or pure water from the mixture itself...but you don't need to split the mixture components entirely.
You might want to research on how distilled water is made (I'm not sure about deionized water); also, reverse osmosis is definitely another.
I have a mixture with relatively low cc. of ethanol. (5 to 10 m%). So it not an azeotrope mixture. What I want is to obtain the pure water. I don't care what happens with the ethanol.
My research is: I would like to make a suspension of SiO2 nanoparticles in water, and I have to use hydrophobic ones. That's the difficulty. One should use trick in order to force the particles into the liquid. I used ethanol, because this lowers the contact angle between the mixture and the particles, and then they go into the bulk liquid. And now I am inquirying what happens if the ethanol is removed? can I remove it simply by boiling? :confused: Will the particles stay into the water, or come out of it? I think they should come out.
Yesterday I tried to boil the mixture, but I couldn't because it was overheated and didn't start to boil. But the particles remained in the liquid and so the ethanol.
Boiling is no problem, today I carry out another measurement. I just don't know what I have to expect. Will the ethanol go away from the liquid, and if yes, how will I recognize? Through the particles behaviour? I hope this is also interesting for you!
I am looking forward to making another boiling. :wink:
A sensitive, and somewhat less rigorous/practical method of determining the purity would be through index of refraction measurements, with pure distilled water as a control. The following page contains some methods for obtaining anhydrous ethanol, however, most of them may not be practical.
Browse the page till you find "Purity"
http://en.wikipedia.org/wiki/Ethanol
Right, then I think I will boil the mixture for several minutes and let's say, in every 3rd minute I will check and compare the refractive index. I will boil until I reach the refractive index of distilled water. Then it means that my mixture is free of ethanol.
Ups, I should take into account the particles effect on refractive index! So I have to compare the mixture not with pure water but with water-particle suspension.
Thanks so much. I hope I can get along.
Be sure to keep things at a relatively same temperature when comparing the index.
Also, repeated measurements and incorporating quantitative analysis should also help in solidifying your data.
hope you have lots of fun;)
  • · Replies 131 ·
11K
  • · Replies 16 ·
44K
