How to Change Tire Pressure Without Affecting Vehicle Stability
  • Thread starter Thread starter gibroni1
    Pressure Tire
The discussion focuses on the dynamics of changing tire pressure without compromising vehicle stability. It establishes that tire pressure is influenced by the mass of the vehicle and the surface area of the tire in contact with the ground, as described by the equation p = (m*g)/a. The conversation highlights that increasing tire pressure results in a harder tire, which reduces the contact patch area, yet does not inherently destabilize the vehicle. Additionally, it notes that pressure in a spare tire, which is not in contact with the ground, serves to maintain the tire's structural integrity rather than support the vehicle's weight.
  • Understanding of basic physics principles, particularly statics and dynamics.
  • Familiarity with tire mechanics and their role in vehicle performance.
  • Knowledge of pressure measurement and tire pressure gauge usage.
  • Basic grasp of vehicle weight distribution and its effects on stability.
  • Research the effects of tire pressure on vehicle handling and stability.
  • Learn about the relationship between tire pressure and contact patch area.
  • Explore the physics of tire deformation under varying loads and pressures.
  • Investigate the role of tire pressure in different driving conditions and environments.
Automotive engineers, vehicle dynamics researchers, and car enthusiasts interested in optimizing tire performance and understanding the physics behind tire pressure adjustments.
gibroni1
Hi All,
This is my first time posting here - I hope you can help!
I'm working on a vehicle shock simulation, and my question below will help me understand some dynamics (really statics) involved in my problem.
How is it possible to change the pressure in your car's tires? If one were to hook up a pressure gauge to a vehicle tire, wouldn't the pressure always have to equal
p = (m*g)/a
where m is a quarter (approximate) of the car's mass, and A is the surface area the gas is acting on.
If the pressure is more or less than this, wouldn't the car not be static?
I understand the volume of the tire is changing when air is added or subtracted, but it seems to me that the pressure should always be the same, jus the mass of air contained in the tire is changing.
I hope my question is clear. I appreciate all help!
As you increase the tire pressure, the tire hardens up more and more, so the area of the contact patch with the ground gets a little smaller. But I don't think that's the main effect. You can also put high pressure into your spare tire, which isn't supporting the car at all, right? So a lot of the pressure goes into creating tension in the rubber of the tire itself.
thanks for the reply, berkeman. I'll have to think about that one.
  • · Replies 20 ·
