Electric Field and an Uniformly Charge Plastic Pipe
The discussion revolves around calculating the electric field generated by a uniformly charged plastic pipe, with specific inner and outer radii and a defined charge density. Participants are exploring how to apply relevant formulas and concepts related to electric fields in cylindrical symmetry.
  • Participants are attempting to determine the charge enclosed within a Gaussian surface to calculate the electric field at specified distances. Questions arise regarding the appropriate Gaussian surface and the volume calculation needed to find the enclosed charge.
Some participants have provided hints and references to relevant resources, while others express confusion about the formulas and concepts involved. There is an ongoing exploration of the underlying principles behind the formulas used, with no clear consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is uncertainty regarding the interpretation of the formulas and the definitions of variables involved.
Swagger
A plastic pipe has an inner radius of a = 35.00 cm and an outer radius of b = 71.00 cm. Electric charge is uniformly distributed over the region a < r < b. The charge density in this region is 30.00 C/m3
A)Calculate the magnitude of the electric field at r = 0.44 m.
B)Calculate the magnitude of the electric field at r = 1.59 m.
I need some help on where to begin. I know the e-field for cylindrical sym. is E=2kQin/rL
I also know that Qin=charge density * Volume.
How do I find the volume so I can find the Qin in both A and B?
Hint: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html"
Have you figured out what gaussian surface to use? Once you do that, you'll be able to calculate the charge enclosed.
I don't understand
What don't you understand?
I don't understand those formulas, we learned E=2kQin/rL. Was my approach the wrong way of doing it. Finding Qin and then using E=2kQin/rL to get the answer.
Yes, but more important than the formula is the underlying principle. Do you know how you got that formula?
Sorry to revive this old thread, but it is the exact same problem I am working on.
What is the formula used to solve the equation? I thought all I would have to do is E = lambda/2pi*epsilon*r^2 but I was wrong.
In the previous posts, in the equation E=2kQin/rL, what is L? Also, how do I find the volume so I can find the Qin in both A and B? Thank you.
  • · Replies 16 ·
