Refractive index to measure temperature
The discussion centers on calculating the refractive index of a liquid (Liquid X) based on its temperature using the formula n = 2.25 – 0.025T. A semi-circular crown glass with a refractive index of 1.75 is used, and the critical angle for total internal reflection is determined using the formula sin(θ_c) = n2/n1. The user successfully solved the problem after receiving guidance on applying the critical angle formula.
  • Understanding of refractive index and its relationship with temperature.
  • Knowledge of total internal reflection and critical angle calculations.
  • Familiarity with the properties of crown glass and its refractive index.
  • Basic trigonometry, specifically sine functions.
  • Explore advanced applications of refractive index in optical engineering.
  • Learn about temperature measurement techniques using optical methods.
  • Study the principles of total internal reflection in fiber optics.
  • Investigate the effects of temperature on the refractive index of various materials.
Students and professionals in optics, engineers working with temperature measurement systems, and anyone interested in the practical applications of refractive index in scientific and industrial contexts.
pavadrin
Here is the question:
A factory uses a beam of light to allow workers to visually check the temperature of a liquid. A semi-circular crown glass (refractive index (n) =1.75) block is placed in a liquid X whose refractive index n changes with temperature T (in °C) according to the formula:
n = 2.25 – 0.025T
A light ray may be directed to the centre of the glass block makes and angle Ө = 60° with the normal
If the ray is totally reflected at O, find the refractive index and the corresponding temperature of liquid X.
___________________________________________​
My working:
[tex]\theta_{critical}=\frac{n_{1}}{n_{2}}[/tex]
from this point onwards I am stuck, any post regarding hints/working/solution will be greatly appreciated
Thank you,
Pavadrin
well, it's sin(theta_c)=n2/n1 , ( n1>n2 )
try working this out, with givens you have.
thank you kindly
thanks for this bit of imformation, i have now solved the problem
15K
21K
