Rivet Joint Design with Gusset Plates - Aluminium Bridge Structure
  • Thread starter Thread starter cabellos
    Joint
The discussion focuses on rivet joint designs with gusset plates specifically for aluminum bridge structures. Participants recommend consulting resources such as the AISC report on seismic behavior and emphasize the importance of standard design manuals from engineering institutes. Phil seeks detailed information on suitable designs for aluminum angle and strip, highlighting the need for reliable references in structural engineering.
  • Understanding of rivet joint mechanics
  • Familiarity with gusset plate applications in bridge design
  • Knowledge of aluminum materials and their structural properties
  • Access to engineering design manuals from organizations like AISC
  • Research the AISC guidelines for riveted connections
  • Study seismic design principles for riveted structures
  • Explore aluminum alloy specifications for structural applications
  • Review case studies on gusset plate designs in bridge engineering
Structural engineers, bridge designers, and construction professionals seeking to enhance their knowledge of rivet joint designs and gusset plate applications in aluminum bridge structures.
cabellos
rivet joint designs...
Hi,
Im in desperate need of a good link where i can read up about rivet joint designs with gusset plates etc. (specifically i need to know suitbale designs for a bridge structure made from aluminium angle and strip) however general information would be just as good. Thanks in advance for the help guys...this would be very much appreciated. :smile:
Phil
Here is a report on the seismic behavior of riveted gusset design.
http://www.aisc.org/Content/ContentGroups/Documents/Steel_Tips1/144_dec_98.pdf
I may not be what you're looking for, but it does have references.
Usually, there are specific manuals from engineering or construction societies/institutes which would provide standard designs.
AISC = American Institute of Steel Construction
