Need help explaining this video
  • Thread starter Thread starter Ukitake Jyuushirou
    Video
The discussion revolves around a video clip where a pilot performs a roll while pouring water into a cup, raising questions about the behavior of the liquid in an upside-down position. The subject area includes concepts of circular motion and forces acting on objects in motion.
  • Participants analyze the forces acting on the tea in the cup during the roll, considering the implications of circular motion. Some suggest examining centripetal force and its role in keeping the liquid contained.
Participants are exploring the mechanics behind the phenomenon, with some providing insights into the forces involved. There is a focus on understanding the principles of circular motion, but no consensus has been reached regarding a specific name for the effect.
Some participants reference the need to consider the speed of the motion and its impact on the forces acting on the liquid. The discussion includes an analogy with a cork on a string to illustrate the concept of centripetal force.
Ukitake Jyuushirou
[MEDIA=youtube]9ZBcapxGHjE[/MEDIA][/URL]
near the end of the video clip, the pilot does a "roll" and at the same time he is pouring water into a cup even though when he is now in an upside down position the water does not spill out of the cup, how is that possible?
near the end of the video clip, the pilot does a "roll" and at the same time he is pouring water into a cup even though when he is now in an upside down position the water does not spill out of the cup, how is that possible?[/QUOTE]The fact that the tea in the cup does not spill is easy to explain but just why the tea continues to pour is a little trickier.
Analyse the forces on the tea in the cup as the plane is doing a roll. What are the forces acting on the tea? (think of the roll as circular motion about some point).
AM
The spoilers are in the same color as the background.
Imagin that you are holding a piece of string with a cork attached to the other end. If you start to spin the string above your head you will that you must hold against to stop the cork from flying away. If you release the string the cork will indeed fly away in the direction of the tangent:
http://img236.imageshack.us/img236/9208/tangent3tz.png
You need to use a force to stop the cork from flying away. This force is used to change the path of the cork so it moves in a cirular movement. This force is called centripetal force and is directed to the center.[/color]
The phenomena can also be observed in roller-costers. What makes a roller-coster continue without "falling off" in a loop?
The short answer is its speed.
The larger the speed the larger is the force that is directed to the center. If that force passes a certain magnitude the item will stay in its orbit.[/color]
You can verify this by yourself in a simple experiment. If you take a glass of water and turn it really quickly around, not fluid will be lost. Do it slower and all of the water will pour out.
is there a specific name for this effect?
This is a simple application of circular motion, as the other posters have said you need only consider the forces acting to explain the effect.
~H
  • · Replies 94 ·
9K
  • · Replies 19 ·
