Thread Closed
Electromagnetism (Phys. 12)
Share Thread Thread Tools
May27-06, 09:21 PM   #1
An ion with a change of 1.6*10^-19 enters a 0.075 T magnetic field. If the ion follows a circular path of radius 0.083m, what is the momentum of the ion?
I tried manipulating Fc = Fmagnet into Momentum = QBr, but that didn't work... any ideas?
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
May27-06, 09:30 PM   #2
Mentor
What do you mean it didn't work?
May27-06, 09:36 PM   #3
Quote by Doc Al
Well, it's a multiple choice question, and the answer I got wasn't any of them.
May27-06, 10:40 PM   #4
Quote by Drevin
[tex]F = qvB[/tex]
You obviously know this. But what must the magnetic force do to keep the charge moving in a circle?
May27-06, 10:46 PM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Drevin
Write down the complete equation and the subsequent steps as you would have, for your homework. What you've written above is not an equation.
May28-06, 07:55 AM   #6
Mentor
Quote by Drevin
Your solution, "Momentum = QBr", is certainly correct. What were the other choices? If the choices were numerical, perhaps you made an arithmetic error.
May28-06, 02:02 PM   #7
Quote by Doc Al
The choices are:
A) 2.7 * 10^-26 kgm/s
B) 1.0 * 10^-21 kgm/s
C) 1.7 * 10^-12 kgm/s
D) 5.2 * 10^-4 kgm/s
The answer I got was 9.96 * 10^-22 using Momentum = QBR
mv = QBr
P = (1.6*10^-19)(0.075)(0.083)
P = 9.96 * 10^-22
That's what I did.
May28-06, 02:18 PM   #8
Recognitions:
Quote by Drevin
The choices are:
mv = QBr
P = 9.96 * 10^-22
That's what I did.
Your answer is correct, except it is written to 3 sig figs, when it should only be written to 2. Do this, and you'll find that one the the given choices is correct.
I misunderstood what you'd written in the OP in my earlier post. After re-reading, it is clear what you did. My bad, sorry.
May28-06, 03:18 PM   #9
Mentor
Quote by Drevin
The choices are:
mv = QBr
P = 9.96 * 10^-22
You should realize that your answer is extremely close to one of those choices, so close that if you had to choose (and you do!) there should be no question as to which one to pick. (The other choices are off by many orders of magnitude--they aren't even close!) And, as Gokul says, if you had worked out your answer to 2 significant figures--as you should have, given the data--you would have found a perfect match. (Since the data you were given only had two significant figures, your answer must have no more than two significant figures.)
May28-06, 03:36 PM   #10
Quote by Doc Al
Ah, yes.. you're correct! (Our class doesn't tend to use sig figs very often, so I think that's where I got confused)
Thanks so much for the help!
I'll write down my steps a little more clearly next time I post a question, too.
Thread Closed
Thread Tools
Similar Threads for: Electromagnetism (Phys. 12)
Thread Forum Replies
AP phys C EM... Academic Guidance 9
How to Study(PHYS II) Academic Guidance 3
Need help with phys problem. Help? Introductory Physics Homework 0
I have a few questions for my Phys Lab Introductory Physics Homework 12
PHYS Help Please Introductory Physics Homework 2
