Thermal Energy and Heat Transfer
The discussion focuses on calculating the time required for a 1000W electric kettle to heat 1.0L of water from 15ºC to 100ºC, considering the kettle's mass of 400g made of iron. The specific heat capacities used are 4200 J/kgºC for water and 460 J/kgºC for iron. The total energy required is calculated as 372,640 J, leading to a heating time of approximately 372.64 seconds or 6.2 minutes. The user initially struggled with applying the power and heat transfer formulas but successfully resolved the calculations by considering both the water and kettle's heat capacities.
  • Understanding of specific heat capacity and its application in thermal energy calculations.
  • Familiarity with the formula e = mcΔt for calculating energy transfer.
  • Knowledge of power calculations using p = W/T.
  • Basic principles of heat transfer and energy conservation.
  • Explore advanced heat transfer concepts, including conduction, convection, and radiation.
  • Learn about the efficiency of different heating appliances and their energy consumption.
  • Investigate the effects of heat loss in real-world scenarios and how to mitigate it.
  • Study the principles of thermodynamics related to phase changes and energy transfer.
Students in physics or engineering, educators teaching thermodynamics, and anyone interested in practical applications of heat transfer calculations.
richievuong
Question:
How long does it take a 1000W electric kettle to bring 1.0L of water to the boiling point if the initial temperature of the water is 15ºC and the kettle is made of 400g of iron?
Assume that no water is boiled, that no heat is lost to the surroundings, and that the kettle is 100% efficient.
Well first thing I did of course is write givens:
Temperature(water, initial) - 15ºC
Temperature(water, final) - 100ºC
Specific Heat Capacity (water) - 4200 J/kgºC
Specific Heat Capacity (iron) - 460J/kgºC
Mass (iron) - 0.4kg
Mass water - 1.0L = 1kg
Power of kettle - 1000W
I know the p= W/T and e=mct formulas but I'm having trouble with applying the 1000W to the heat transfer formulas. The other questions I've done,only required me to do mcΔt = -mcΔt with some latent fusion/vapourization in there.
Confused where to start...
richievuong said:
Question:
Mass (iron) - 0.4kg
Find how much energy is needed to bring the temperature of the water and iron kettle from 15ºC to 100ºC . Then work out how long it would take to deliver that energy at 1000 Joules/sec.
AM
oh well now i kind of figured that
|E heat lost| = |E heat gained|
so e = mcΔt
e= (1)(4200)(100-15)
e= 357000
p=W/T
1000W = 357000J/T
T = 357s (5.9mins)
answer said 6.2...either I'm missing some steps, or I'm just completely wrong...i didn't fit in the stuff for iron...
EDIT: haha nvm i figured it out
e = mcΔt
e = (0.4)(460)(100-15)
e(iron) = 15640 + 357000 = 372640J/1000= 372.64 (6.2mins)
thanks anyway
