How Do You Determine Horizontal Asymptotes in Functions?
  • Thread starter Thread starter roy5995
    Horizontal
The discussion focuses on determining horizontal asymptotes in functions, specifically analyzing the function y=2xe^-x^5. It establishes that as x approaches positive infinity, the function approaches 0, indicating that y=0 is the only horizontal asymptote. The conversation also highlights that there are no horizontal asymptotes as x approaches negative infinity. Additionally, it mentions L'Hôpital's rule as a derivative test for finding horizontal asymptotes when limits result in indeterminate forms.
  • Understanding of horizontal asymptotes in calculus
  • Familiarity with limits and their evaluation
  • Knowledge of L'Hôpital's rule for indeterminate forms
  • Basic differentiation techniques
  • Study the application of L'Hôpital's rule in various functions
  • Learn about the behavior of exponential functions as x approaches infinity
  • Explore more examples of finding horizontal asymptotes in rational functions
  • Investigate the differences between horizontal and vertical asymptotes
Students and educators in calculus, mathematicians analyzing function behavior, and anyone seeking to deepen their understanding of asymptotic analysis in mathematical functions.
roy5995
How do i find horizontal asymptotes?
Is there a derivative test for that?
for example how do i find the asymptotes for y=2xe^-x^5 i know that there has to be a horizontal one, are there any others?
You CAN use derivatives if you really want to: Find the derivative and see where it is approaching 0.
But you don't need to do that. Since a horizontal line extends to infinity, the only way a graph can have a horizontal asymptote is if the function approaches that value as x goes to + or - infinity.
In the particular case y=2xe-x^5, as x gets large, x^5 is much larger so you have e to a huge negative power. Even with x multiplying that, it will go to 0. y= 0 is a horizontal asympote. On the other hand if x goes to - infinity, for x a huge negative number, x^5 is a much larger negative number so -x^5 is a huge positive number. e-5^x is huge and -xe-x^5 is a huge negative number. here is no horizontal asymptote as x goes to negaitve infinity.
y= 0 is the only horizontal asymptote.
If you differentiate y, you get y'= 2e-x^5- 10x^5 sup[-x^5[/sup]. Since an exponential dominates any power of x, that will be close to 0 for large positive x, just as I said before.
To find horizontal asymptotes, you need to look at the behavior of the function as x approaches positive and negative infinity. If the function approaches a constant value as x gets larger or smaller, then that constant value is the horizontal asymptote.
There is a derivative test for finding horizontal asymptotes, called the L'Hopital's rule. This rule states that if the limit of a function as x approaches infinity or negative infinity is of the form 0/0 or infinity/infinity, then you can take the derivative of both the numerator and denominator and evaluate the limit again. If the new limit still results in 0/0 or infinity/infinity, you can repeat the process until you get a non-indeterminate form. The resulting value will be the horizontal asymptote.
In the given example, y=2xe^-x^5, as x approaches infinity, the exponential term dominates and the function approaches 0. Therefore, the horizontal asymptote is y=0. There are no other horizontal asymptotes for this function.
  • · Replies 20 ·
