Which Curve Intersects Every Curve of the Family y = 1/x + k at Right Angles?
  • Thread starter Thread starter tandoorichicken
    Calculus Weird
The equation of the curve that intersects every curve of the family y = 1/x + k at right angles is y = -x^2. This conclusion is derived from the derivatives of both curves, where the slope of the curve y = 1/x + k is -1/x^2, and the slope of y = -x^2 is -2x. Setting these slopes equal results in the intersections occurring at x = ±1, confirming that the curves intersect at right angles. Thus, the definitive answer to the question posed is option b) y = -x^2.
  • Understanding of calculus, specifically derivatives
  • Familiarity with the concept of slopes and perpendicular lines
  • Knowledge of the family of curves represented by y = 1/x + k
  • Ability to solve equations involving derivatives
  • Study the properties of derivatives and their geometric interpretations
  • Explore the concept of orthogonal curves in calculus
  • Learn about the family of curves and their transformations
  • Investigate other examples of curves that intersect at right angles
Mathematics students, calculus instructors, and anyone interested in the geometric properties of curves and their intersections.
tandoorichicken
Which of the following is an equation of a curve that intersects at right angles every curve of the family y = 1/x + k where k takes all real values?
a)y= -x b)y= -x^2 c)y= -x^3/3 d)y=x^3/3 e)y=ln x
Are you sure that you don't mean
[tex]y=\frac{1}{x} + k[/tex]
then [tex]\frac{dy}{dx}=\frac{-1}{x^2}[/tex]
any suitable function would have the negative reciprocal slope, so
[tex]\frac{df}{dx}=\frac{x^2}{1}=x^2[/tex]
sp
[tex]f(x)=\frac{x^3}{3}+C[/tex]
and the answer is d.
The correct answer is b) y = -x^2. This is because for any value of k, the curve y = 1/x + k will intersect the curve y = -x^2 at right angles. This can be seen by taking the derivative of both curves and setting them equal to each other, which results in the equation 1/x^2 = -2x. Solving for x gives the intersections as x = ±1, which are indeed at right angles. Therefore, any curve of the form y = -x^2 will intersect all curves of the family y = 1/x + k at right angles.
  • · Replies 38 ·
  • · Replies 25 ·
