Understanding Water Pressure: Tips for Measuring Flow from a 250 Gallon Tank
The discussion revolves around understanding how to measure water pressure from a 250-gallon tank, specifically focusing on the pressure of water exiting through a 3/8-inch nozzle. The scope includes theoretical considerations and practical implications of fluid dynamics.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant inquires about determining the water pressure from a nozzle based on the tank's weight and height.
  • Another participant suggests that the height of the tank is a critical factor but admits uncertainty regarding the equations involved.
  • A third participant claims that pressure is approximately 1 atm (14.7 psi) for every 33 feet of height, noting that this holds until water compression becomes significant, which may require an exceptionally tall tank.
  • Another participant states that while nozzle diameter does not affect pressure, it influences the exit speed of the water, emphasizing that pressure is determined by the height of water above the nozzle (p=ro*g*h).
Participants express differing views on the relevance of nozzle size and the specific equations needed to calculate pressure, indicating that multiple competing perspectives exist without a clear consensus.
There are unresolved assumptions regarding the height of the tank and the conditions under which pressure calculations apply, as well as potential dependencies on the definitions of pressure and flow dynamics.
craxma68
If there is anyone out there that can answer this it would be greatly appreciated. I am stuck with this one.
At normal pressure of its own weight how can I determin the water pressure of water coming out of a 3/8ths in. nozzle out of a 250 gallon tank?
i think that it would depend on how tall the tank is. but i am not sure of the equasioons to figure it out. i am no expert and am probably missing something.
Nozzle size doesn't matter. Initially you get about 1 atm (14.7psi) of pressure for every 33 feet of height, which holds until the pressure starts to significantly compress the water, but this would require a very tall tank.
Nozzle diameter doesn't affect the pressure, but it does affect the exit speed of the water. The pressure is only a function of the water level height above the nozzle (p=ro*g*h).
  • · Replies 32 ·
14K
  • · Replies 56 ·
  • · Replies 24 ·
