How Do Manganese Redox Reactions Work with Nitric Acid and Potassium Iodate?
  • Thread starter Thread starter Mattara
    Reactions Redox
The discussion focuses on the redox reactions involving manganese, nitric acid (V), and potassium iodate (KIO4). The oxidation of manganese to Mn2+ ions is represented by the overall reaction: 3Mn + 6HN03 -> 6NO3- + 3Mn2+ + 6H+. The second part involves the reaction of Mn2+ with KIO4, resulting in MnO4- and I2-. The participants emphasize the importance of balancing charges and understanding the reduction of IO4- to IO3- under varying conditions.
  • Understanding of redox reactions and oxidation states
  • Familiarity with nitric acid (V) and its properties
  • Knowledge of potassium iodate (KIO4) and its behavior in reactions
  • Ability to balance chemical equations
  • Study the mechanisms of redox reactions in acidic solutions
  • Learn about the properties and reactions of potassium iodate (KIO4)
  • Explore the reduction pathways of iodate ions (IO4-) under different conditions
  • Investigate the role of protons in acid-base reactions and their impact on redox processes
Chemistry students, educators, and researchers interested in redox chemistry, particularly those focusing on manganese oxidation and iodate reactions.
Mattara
Hello,
I've been working on some redox reactions for the oxidation of manganese.
Question:
Write the complete formulae for the redox reactions below:
i.) Manganese reacts with nitric acid (V) to form Mn2+ ions.
ii.) The Mn2+ ions reacts with potassium iodate, KIO4 to form MnO4- (VII)
My Solution:
i.)
Oxidation: 3Mn (s) --> 3Mn2+ (aq) + 6e- (aq)
Reduction: 6HN03 (aq) + 6e- (aq) --> 6N03- (aq) + 6H+ (aq)
Overall reaction: 3Mn + 6HN03 -> 6NO3- + 3Mn2+ + 6H+
Is this correct? If so, does the single protons regenerate the acid and/or become attached to substances like water?
ii.)
Oxidation: Mn2+ + X -> MnO4- + ?H+
Reduction: IO4- + ?H+ -> I? + 4H2O
Overall reaction: Mn2+ + IO4- -> MnO4- + I2-
I'm having trouble with this part of the question. I does not have -II as one of its common oxidation number.
Any help or hints would be greatly appreciated :smile:
Best Regards,
Mattara
Mattara said:
Hello,
Question:
My Solution:
i.)
Take a step back and ask yourself,
metal + acid --> salt + (?)
You do not get protons. Look at the reduction reaction you've written. The charge is not balanced. Fix that one mistake using above hint and you're good.
ii.)
On the RHS, you have Mn, H and O. On the left, you have Mn. Ergo, X is simple H2O.
This is a little tricky. The reaction actually depends on the conditions. Mostly, you just have to know what happens to IO4- under different conditions. Typically, it will first get reduced to IO3-. Unless someone else suggests otherwise, you could go with that.
9K
23K
28K
11K
9K
14K
