How Do I Double Integrate Discrete Acceleration Data to Find Displacement?
To double integrate discrete acceleration data to find displacement, one must first calculate instantaneous velocities from the acceleration values. This involves creating a third column that represents velocity at each time interval based on the acceleration data. After obtaining the velocity values, the same integration process is repeated to derive displacement for each interval. The total displacement can then be computed by summing these individual displacements.
  • Understanding of numerical integration techniques
  • Familiarity with discrete data analysis
  • Proficiency in using spreadsheet software or programming languages for data manipulation
  • Knowledge of basic physics concepts related to motion
  • Learn numerical integration methods such as the Trapezoidal Rule or Simpson's Rule
  • Explore data manipulation techniques in Python using libraries like NumPy or Pandas
  • Study the principles of kinematics to better understand the relationship between acceleration, velocity, and displacement
  • Investigate tools for visualizing time series data to analyze the results of integration
Engineers, data analysts, and physicists who need to analyze motion data, particularly those working with discrete acceleration measurements to derive displacement values.
sanjayindia
I understand that I need to double integrate to convert acceleration signal to displacement signal. If I have an acceleration signal at discreet times (no algebraic realtion to relate accelration to displacement), how do I double integrate? In other words i just have 2 colums, one with time and the other with acceleration. How do I double integrate? Please advice
Can you, from the two existing columns, generate a third column that lists "instantaneous" velocities at those times ? Once you do that, repeat the algorithm to generate displacements for each interval. From these last numbers, you should be able to find the total displacement.
  • · Replies 17 ·
  • · Replies 38 ·
