Redshifts, what frequencies are they looking at?
  • Context: Undergrad
  • Thread starter Thread starter dimensionless
    Frequencies
The discussion centers on the methods used by scientists to investigate redshifts in astronomical observations, particularly whether they focus on specific frequencies or the overall distribution of spectral energy. It encompasses theoretical aspects of spectroscopy, observational challenges, and the implications of redshift measurements in astrophysics.
  • Some participants note that redshifts can be investigated by examining specific spectral lines, which serve as "fingerprints" for identifying elements in distant objects.
  • Others argue that in cases where spectral lines are not discernible, broadband spectral properties can be used to estimate redshifts by comparing light distributions across different wavelengths.
  • A participant mentions the challenges of obtaining precise redshift measurements from faint galaxies due to intervening gas and dust, complicating the identification of spectral lines.
  • There is a discussion about the mathematical definition of redshift, with some participants clarifying that redshift is defined as the ratio of the change in wavelength to the original wavelength.
  • Some participants express differing views on the interpretation of redshift calculations, particularly regarding the relationship between wavelength and redshift values.
  • There are acknowledgments of the difficulties faced in obtaining accurate redshift data from poor observational conditions, such as cloudy weather.
Participants generally agree that both specific spectral lines and broadband properties can be used to investigate redshifts, depending on the circumstances. However, there is disagreement regarding the interpretation of redshift definitions and calculations, with no consensus reached on the nuances of these definitions.
Participants highlight limitations in observational capabilities, particularly for distant objects, and the dependence on the availability of spectral lines for accurate redshift measurements. The discussion also reflects varying interpretations of mathematical definitions related to redshift.
dimensionless
I looked at a spectrogram of our sun several months ago. It contained a whole plethora of frequencies. It appeared that there were many thousands of frequencies in the visible spectrum alone.
When scientists investigate redshifts, do they look at a specific frequency, or do they just examine the distribution of spectral energy?
Space news on Phys.org
If you can obtain a spectrum then you compare wavelengths of specific transitions. With some very distant and faint objects a spectrum as such cannot be obtained and the Planck spectrum itself has to surfice, if you think you know its efffective temperature.
One example of such an object is the Hubble ultra deep field object UDF033238.7-274839.8 aka HUDF-JD2 , a 6 x 1011Msolar galaxy at an inferred z = 6.5.
Dan Stark, a graduate student at Caltech, attempted to pinpoint the galaxy's distance by obtaining detailed spectra using both the 10-meter Keck II and the 8m Gemini telescopes, but he was unable to do so. "We have now reached the point where we are studying sources which lie beyond the spectroscopic capabilities of our current ground-based facilities," he says. "It may take the next generation of telescopes … to confirm the galaxy's distance."
Instead, the team estimated the distance to HUDF-JD2 indirectly by looking at its energy at different wavelengths.
"It's not quite as convincing as a spectrum, and we estimate a 75-percent chance that we have the right distance," Ellis tells Astronomy. "There's no real prospect of getting a more accurate distance with current facilities."
Garth
They look at spectral lines. You can think of each element having a sort of "fingerprint" encoded in the spacings of its various spectral lines. This "fingerprint" can positively identify a specific element's emissions. When the spectral lines of the light from some known element from a distant astronomical object all appear at lower frequencies than samples of the same element in a laboratory, the redshift can be calculated.
- Warren
We look at them all - and they are consistent: twice the wavelength gives twice the redshift from the Hydrogen line to visible
Both answers given so far are correct in some circumstances. Most redshifts that are of high precision are obtained by examining the positions of spectral lines. We know exactly where the lines should be located in the rest frame, so we can calculate the redshift to within (or often better than) the resolution of the spectrograph.
Other times, when there is no spectroscopic data available or there aren't enough lines to identify the transitions they correspond to, we use the broadband spectral properties. This means, basically, that we compare the relative amounts of light of different colors (say the total blue light vs. the total red light) to what we would expect from a particular type of source. High-redshift sources (like quasars or galaxies) don't have Planck spectra, but still have relatively predictable spectral properties.
This is not quite correct. Redshift is defined by the following;
[tex]z\equiv \frac{\Delta\lambda}{\lambda}=\frac{\lambda_{obs}-\lambda_{lab}}{\lambda_{lab}}[/tex]
So if the [tex]H\alpha[/tex] is observed at [tex]\lambda_{obs}=13126[/tex] angstroms (ie twice the laboratory wavelength), then the redshift of the observed object is z=1.
Good catch matt.o. Math is good! To be fair, however, ST is talking about spectroscopy wrt faint galaxies. It is very difficult to sort out the 'lines' with all the intervening gas and dust.
Matt.o is correct, but it doesn't contradict anything I said (as best I can tell, anyway). I was just describing a method of approximating a redshift without access to the spectral lines, the definition he gave is still correct at any point in the spectrum.
Hi Chronos. I wasn't contradicting anything ST was saying, just what ratfink said was slightly incorrect.
I am well aware of the difficulties in obtaining redshifts with weak to no lines! I have tryed to get redshifts out of crappy, cloud affected and under-exposed data before! Damn cloudy weather...
In what way am i incorrect?
aH! i SEE WHAT YOU MEAN.
sorry, twice the wavelength gives twice the 'shift' or redshift. It all boils down to z is called 'redshift' and delta lambda is also called 'redshift'. I am using redshift 'delta lamba' as being proportional to wavelength here. 'z' is also known as redshift.
If a photon is redshifted it is redshifted. No probs.
No, that is the way redshift is properly defined. I have never seen redshift defined as just [tex]\Delta\lambda[/tex].
Apologies for the confusion. My comment was wrt what ratfink said, not ST.
  • · Replies 18 ·
  • Poll Poll
  • · Replies 17 ·
