Thread Closed
truck tire pressure / load on road
Share Thread
Jun6-06, 06:14 PM   #1
hi to all
problem:
a truck with a total weight of 5000kN and with 4 wheels will be placed on 4 glass cups each under one wheel. if each tire has a internal air pressure of 2MPa. what will be the load on each cup? and if the truck was standing on the road with out the cups under wheels what will be the load on the road.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jun6-06, 08:42 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by pescador
hi to all
problem:
So what are your thoughts on how tire pressure affects the downward force of the truck?
AM
Jun7-06, 01:25 AM   #3
if the tires were solid then i can exactly say that the load per tire transfering down to road is 5000/4 = 1250 kN
but the tires are like pneumatic pillows. so some of the load should be carried by the tire surface.
Jun7-06, 01:27 AM   #4
the load effecting to road should be the surface of the interface between the tire and road * tire internal pressure.
Jun7-06, 09:28 AM   #5
Recognitions:
Quote by pescador
So if we, say, let out half the tire air (and, therefore, reduced pressure by half), the load on the road would reduce by half?
AM
Jun7-06, 03:22 PM   #6
no because if we let the half of air out. then the touching surface area to the road of the tire will increase and the load will remain the same.
Jun7-06, 03:42 PM   #7
Recognitions:
Quote by pescador
So what effect does tire pressure have on the force exerted on the ground by the truck?
AM
Jun7-06, 04:04 PM   #8
sees like nothing if i dunt make a wrong model
Jun7-06, 04:08 PM   #9
if we say that it has no effect on the load why we have so mch pressure on the tires?
Jun7-06, 04:42 PM   #10
Recognitions:
Quote by pescador
The pressure inside the tires is balanced by the forces holding the tire to the wheel. It contributes no net force to the road.
AM
Jun8-06, 01:04 AM   #11
got it
so if i have a truck of total weight is a N on 4 tires with a tire pressure of p Pa then the surface area touching the road per tire should be
[tex] N/(4*p) [/tex]
so there force to the road will be pressure times the surface area so N again.
Jun8-06, 01:07 AM   #12
do u have a source that tells theory about the pressurized systems with flexible layer?
Jun8-06, 01:15 AM   #13
ok lets change the subject.
i got a basketball it stands still on the road. then i come and start pressing on the ball with my one foot. the ball will be deformed from the point that i press. and also the area of the ball touching the road will be deformed and increase.
i think that because of the volume decrease in the ball the pressure will increase and then this pressure will transfer my weight to the road with it's increased area touching the road. so there reaction force from the road will increase.
true?
Jun8-06, 01:38 AM   #14
Recognitions:
Quote by pescador
true?
You are making it too complicated. The tire pressure does not affect the load on the road. At best, it changes the distribution of the load so changing air pressure may change the pressure on the road somewhat. But that is all. The pressure in the tires has no bearing on the total force on the road.
AM
Jun8-06, 01:56 AM   #15
:) ok.
last one. what will happen if i increase the load (add more things to truck) there must be a limit for that if i put more weight and suppose that the tire surface is strong enough. the air will go upwards and the truck will touch the bottom. but if i put more pressure on it will lift the truck again.
so there must be a connection, hmm dunno may be alittle mixed up
Jun8-06, 08:31 AM   #16
Recognitions:
Quote by pescador
:) ok.
If you have a deflated tire and pump it up, the truck will rise as the air pressure builds up inside the tire. The air in the tire does work as it expands. This work raises, slightly, the centre of mass of the truck and increases its gravitational potential energy. But (when the truck stops moving up) the force exerted on the road is exactly the same as it was with the deflated tire.
Draw a diagram showing the forces on the truck and on each wheel. Since the truck is not accelerating in the vertical direction, the vertical forces sum to 0. Those forces are the weight of the truck (down) and the normal force of the road on the tires (up). The air in the tire is exerting a force in both directions but is balanced by the mechanical forces holding the tire onto the truck. It would be exactly the same if the truck was sitting on four vertical springs.
AM
Jun12-06, 04:45 PM   #17
so can we clearly say that the weight of truck is transfered to pressured tire by [tex] surface area 1*pressure [/tex] and it transfers the same load to the road by [tex] surface area 2*pressure[/tex]
surface area 1 : area of the rigid part touching to the tire
surface area 2 : area of the tire touching to road
Thread Closed
Similar discussions for: truck tire pressure / load on road
Thread Forum Replies
Friction and Tire Pressure Classical Physics 9
Distance traveled by a accelerating truck with steel load. Introductory Physics Homework 1
tire pressure question Engineering, Comp Sci, & Technology Homework 2
load something from a truck Engineering Systems & Design 6
my bicycle tire pressure General Physics 4
