Artificial Gravity: Is It Possible?
  • Context: Graduate
  • Thread starter Thread starter scott1
    Gravity
The discussion revolves around the feasibility of creating artificial gravity without relying on Coriolis forces, exploring various theoretical and speculative approaches to the concept. Participants engage with ideas from general relativity, particle physics, and engineering proposals, while examining the implications of mass, acceleration, and gravitational effects.
  • Some participants question whether artificial gravity can be created without real mass, suggesting that any attempt would still involve real gravitational forces.
  • One participant proposes that accelerating a large number of particles to near light speed could create a gravitational effect, although this raises questions about whether this would be considered artificial gravity.
  • Concerns are raised about the implications of relativistic mass and whether it contributes to gravitational fields, with some arguing that it would not yield artificial gravity.
  • Another participant references Robert Forward's proposals involving gravitomagnetic effects, noting potential flaws in the concept and the requirement for extremely dense materials to achieve the desired effects.
  • Discussions include the nature of gravitational fields produced by moving bodies and the complexities introduced by general relativity, including the distinction between gravitational mass and inertial mass.
  • Some participants highlight the limitations of using kinetic energy to create artificial gravity, emphasizing the need for significant mass to generate substantial gravitational effects.
Participants express a range of views, with no consensus on the feasibility of creating artificial gravity without real mass or the effectiveness of proposed methods. The discussion remains unresolved, with multiple competing ideas and hypotheses presented.
Participants note various assumptions and limitations, including the dependence on definitions of mass and gravity, the challenges of achieving the necessary conditions for artificial gravity, and the unresolved nature of certain theoretical claims.
scott1
Is it possible to create artificial gravity without using coriolis forces?
Well, Coriolis forces are a result, not a cause. I assume that you mean centrifugal force in place of gravity, imparted by spinning a spacecraft . As far as I know, the only way that you could 'create' gravity would still involve 'real' gravity as opposed to artificial. That would mean either harnessing gravitons, if they even exist, or using condensed matter such as neutronium or micro-black holes to impart a field.
Right now its still science fiction to create gravity without having mass.
I suppose you mean inertial forces (of which the coriolis force is a very special one - mostly one uses the centrifugal force).
According to GR, gravity forces ARE inertial forces. This is the equivalence principle. On the surface of the earth, we feel an m.g force, because the reference fixed to the surface of the Earth is accelerating upward (according to the metric of spacetime here) with an acceleration of 1g wrt a local inertial frame.
So, within the framework of GR, there's no way to create artificial or real gravity forces which are not inertial forces, because both are one and the same.
What about accelerating a very huge number of electrons or protons to near light speed? (Ignoring the tremendous amount of energy this would take).
This is supposed to do what ?
Wouldn't the mass of highly accelerated particles increase and therefore increase the strength of a gravitaional field?
The mass would indeed increase, making this regular gravity, not artifical. To get a 1G gravitational field from such particles, one would have to accelerate tham 'till they were almost as massive as the Earth.
Also, their has been cnsiderable debate as to wether relativistic mass (the kind of mass gained by accelerating
) even has a gravitational effect. a lot of that debate has been right here in these Forums.
I've seen proposals by Robert Forward to create something resembling artifical gravity
The technical reference is:
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=AJPIAS000031000003000166000001&idtype=cvips&gifs=yes
but I don't have access to it. I do have the popularized version published in "Indistinguishable from Magic", there is also some information available online in
http://www.aleph.se/Trans/Tech/Space-Time/art_grav.txt
The basic idea relies on gravitomagnetic effects. Unfortunately, there are several problems with the idea.
First of all, I don't think the idea will work as he describes it (more later).
Second of all, if it does work the way Forward thinks it will, it requires white-dwarf star density material accelerated to near-light speeds in a few milliseconds (Forwards own description, from "Indistinguishable from Magic".
Third of all, the field is not constant, it's an "AC" effect. So if it worked the way Forward thought, as you pumped the white-dwarf star fluid through the coils, you would "shake" anything in the center up and down.
The problem that I have with Forward's idea is that the the magnetic field of a torroid is zero, except in the region within the windings.
http://library.thinkquest.org/16600/advanced/ampere.shtml
Thus there will be no electric or magnetic field at the center of a torroid from what I can see. So I think that Forward has probably made a mistake in borrowing electrical engineering, and that his gravitational version of a torriod with hyperdense fluids in tubes replacing currents will have no fields at its center, either.
It would be less if the center of mass of the accelerated particles very much closer to the observer. Anyway, this seems more like sci-fi than fact.
Not entirely zero, depending on how the currents are set up. If you have one continuous spiral around the toroid (as illustrated in your link), you'll have SOME field in the middle of the torroid due to the "drift" current.
The kinetic energy of a body does contribute to it's "gravitational mass". As others have mentioned, this has been discussed here before. See for instance
http://arxiv.org/abs/gr-qc/9909014
According to the general theory of relativity, kinetic energy contributes to gravitational mass. Surprisingly, the observational evidence for this prediction does not seem to be discussed in the literature. I reanalyze existing experimental data to test the equivalence principle for the kinetic energy of atomic electrons, and show that fairly strong limits on possible violations can be obtained. I discuss the relationship of this result to the occasional claim that ``light falls with twice the acceleration of ordinary matter.''
There are some tricky points to this issue that I will gloss over, but I will say that it is definitely a mistake to think of the field of a moving body as being uniform in all directions. It is closer to the truth to think of the "field" of a moving body as being "squished", strong in the direction transverse to the motion, and weak in the direction parallel to the motion.
I'll point out that this is only an approximation. The reason that it is an approximation is that the concept of a "field" isn't really quite right, gravity is not really a force in GR but a curvature in space-time. In a static system, the force explanation can be made equivalent to the curvature explanation, but in a non-static system the curvature explanation turns out to be more general than the "force" explanation.
The end result, however, is that hot gas (consisting of moving atoms) does "weigh more" than a cold gas (consisting of less-rapidly moving atoms). This end result is not an approximation because a hot gas (in a container) is a static system.
While theoretically correct, this result is not of much practical utility to those wanting to create artifical gravity, though. One still needs something very heavy to cause significant gravity, and it is more convenient to use normal dense solid objects than to attempt to contain a relativistic gas.
For static systems without significant time dilation, one can even use Gauss's law to say that a closed surface of area A surrounding a mass M will have the surface intergal of normal-force*Area of surface A equal to 4*Pi*G*M, where M is the enclosed mass. Given a desired gravity g, and a desired area A, Gauss's law says that one needs a mass of at least g*A/4*Pi*G to generate it.
This equation breaks down if one has significant time dilation, or if the system is not static, however. The existence of "negative mass" would be another way around this constraint.
If I'm understanding this right, that's only because of the finite resistance of the wire. I don't this this sort of parasitic effect is going to help Forward's propsal any. There isn't really any "wire" or "resistance", the electrostatic equivalent of Forwards proposal is a bunch of charge forced to flow around the torus. There will certainly be forces due to the net (high) charge on the torus, these are just the gravitational field of the torus. There won't be any gravitomagnetic fields in the center of the torus, Forward's proposal demands a strong, time-varying gravitomagnetic field.
Well, I probably shouldn't have used the word "drift" considering it has another meaning in the same context.
I'm just saying that since the coils in the toroid are not parallel to the cross-section of the toroid (since we wound the wire around the loop in a spiral), we'll get some field in the middle.
To illustrate: Set our cylindrical coordinates at the center of the toroid, with z pointing up. In a perfect toroid, all the turns have current running in only two directions: z and s. But since we have one long wire precessing along the entire toroid length, the current will also have a phi component. This generates a field in the middle of the torus.
Basically, all I'm arguing is that the field is zero in the middle only if the torus is perfectly made.
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 32 ·
  • · Replies 38 ·
