Izit possible fabricate the quantum dot by cvd?
  • Context: Graduate
  • Thread starter Thread starter takeshi_ccw
    Dot Quantum
The discussion centers on the feasibility of fabricating gallium nitride (GaN) quantum dots using chemical vapor deposition (CVD) techniques, specifically with nanoporous alumina or nanoporous silicon as substrates. The participants highlight that III-V quantum dots have been successfully produced using metal-organic chemical vapor deposition (MOCVD) for over a decade, utilizing a self-assembly method that involves depositing monolayers on a GaAs substrate under tensile strain. While the original poster seeks alternatives to molecular beam epitaxy (MBE), it is noted that the substrate growth typically requires MBE, although further exploration of MOCVD-only methods is suggested.
  • Understanding of chemical vapor deposition (CVD) techniques
  • Knowledge of III-V semiconductor materials, specifically gallium nitride (GaN)
  • Familiarity with self-assembly processes in nanostructure fabrication
  • Experience with metal-organic chemical vapor deposition (MOCVD) methods
  • Research the self-assembly technique for quantum dot fabrication using MOCVD
  • Investigate alternative methods for growing GaN substrates without MBE
  • Explore the properties and applications of nanoporous alumina and nanoporous silicon in semiconductor fabrication
  • Study the impact of tensile strain on the formation of quantum dots in III-V materials
Researchers and engineers in the fields of nanotechnology, semiconductor fabrication, and materials science, particularly those focused on quantum dot production and alternative deposition methods.
takeshi_ccw
izit possible if i take nanoporous alumina or nanoporous silicon into the cvd.
use the gallium powder n flow the ammonia gas...
can it make a gaN quantum dot?
any idea to fabricate quantum dot without mbe?
i think there sure has a simple and cheap way to make it...
any idea?
tanx
III-V quantum dots have been made by MOCVD for at least over a decade now. The trick (I think it's called self-assembly) is to deposit a few monolayers over a (typically GaAs) substrate with a large lattice mismatch that puts the film in tensile strain. If you keep the number of monolayers down below a certain limit, the strain forces the film to break up into islands, and voila, you have your dots.
There's probably several more ways to do this that I'm not aware of.
Edit : In the above technique, the substrate is likely grown by MBE, so you'll have to "get" that from someone else. But I'll take a look to see if anyone has done this entirely on a MOCVD unit.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 46 ·
