How Is pH Calculated for a More Alkaline Solution?
  • Thread starter Thread starter petuniac
    Ph
The discussion revolves around calculating the pH of an unknown solution that is stated to be 40 times more alkaline than neutral water, which has a pH of 7. Participants are examining the mathematical reasoning behind the calculation and the assumptions made in the process.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate the pH using logarithmic relationships but questions their result. Other participants point out potential errors in the mathematical steps and suggest alternative approaches to express the relationship using logarithms.
The discussion is active, with participants providing feedback on the original poster's calculations and suggesting re-evaluation of specific steps. There is no explicit consensus yet, but guidance has been offered regarding the logarithmic approach.
Participants are working under the assumption that the relationship between pH and alkalinity is correctly understood, but there are indications that some foundational calculations may need to be revisited.
petuniac
Question is:
An unknown solution is 40 times more alkaline than neutral water which has a PH of 7. Determine the PH of the unknown solution.
Here is what I have:
40 = (log base 10 x)/(log base 10 7)
40 = 10^(x-7)
10^1.4 = 10^(x-7)
1.4 = x - 7
x = 8.4
The answer is supposed to be 8.6? Not sure where my mistake is.
Thanks for your help.
Is the first line correct? Assuming the second is, it's wrong to go from 40 to 10^1.4, recheck that.
Like td said, your exponent of 1.4 in that line is wrong.
Think of the following equation:
10y=40
Now you can see how to write y in terms of logarithms. Then when you find what y is you will have 10y=10(x-7).
Note that this is kind of the work-around method. It's easier to look at the line 40=10(x-7) and take the log base 10 of both sides.
Thanks! Not sure what I was thinking.
  • · Replies 16 ·
