Will a Comet Fragment Strike Earth in May 2006?
    Meteorite
The discussion revolves around the potential impact of comet fragments on Earth, specifically focusing on the events surrounding May 2006 and the implications of the annual Arietid meteor shower. Participants explore the nature of the impact reported in Norway, the characteristics of asteroid 1566 Icarus, and the relationship between these events and the comet 73P/Schwassmann-Wachmann 3.
  • One participant notes that an impact in northern Norway was comparable to the Hiroshima atomic bomb, raising questions about the size of the resulting earthquake and the absence of visible impact marks.
  • Another participant suggests that the impact might be related to the annual Arietid meteor shower and proposes that the meteorite could be a fragment of asteroid 1566 Icarus.
  • Details about asteroid 1566 Icarus are discussed, including its dimensions and density, with some uncertainty about its exact physical characteristics.
  • Participants mention that Earth is currently within a debris stream from the Arietid meteor shower, which is believed to be linked to asteroid 1566 Icarus.
  • One participant questions whether the event is connected to a rumored catastrophic impact expected on May 25, 2006.
  • A NASA announcement is cited, stating that fragments of a comet will not hit Earth and dismissing fears of mass extinctions or tsunamis related to comet 73P/Schwassmann-Wachmann 3.
Participants express differing views on the likelihood of a comet fragment striking Earth, with some supporting NASA's reassurances while others remain skeptical or curious about the implications of the meteor shower and the impact in Norway. The discussion does not reach a consensus on these points.
There are limitations regarding the assumptions made about the impact's effects, the definitions of the meteor shower's origins, and the unresolved nature of the physical characteristics of asteroid 1566 Icarus.
Evo
Staff Emeritus
As Wednesday morning dawned, northern Norway was hit with an impact comparable to the atomic bomb used on Hiroshima.
http://www.aftenposten.no/english/local/article1346411.ece
How large of an earthquake does that cause? I'm surprised we haven't seen images of the rock or the mark it left.
As of 18:52 MDT no one has found the impact crater.
Believe it or not, a lot of the surface of Earth is essentially uninhabited.
Circa 90% - see this discussion of extraterrestrial objects:
http://www.planetary.org/explore/topics/near_earth_objects/threat.html
asteroid 1566 Icarus...
This event appears to be related to the 'annual Arietid meteor shower'.
It is probable that this meteorite is a fragment of the asteroid 1566 Icarus.
It certainly would be interesting to study a fragment of the asteroid 1566 Icarus.
It appears that Earth will enter closest approach to the asteroid 1566 Icarus orbit on June 17, 2006.
It appears that Earth will enter the asteroid 1566 Icarus orbital plane on June 19, 2006.
[/Color]
1566 Icarus
Physical characteristics
Dimensions: 1.4 km (diameter)
Mass: 2.9×10^12 kg
Density: 2 ? g/cm³
Probably a much higher density than this, 1566 Icarus density: 5-9 g/cm³
[/Color]
Annual Arietid meteor - 06-08-2006
DAYLIGHT METEORS: There's a meteor shower in progress today--but don't expect to see any meteors. The display peaks in broad daylight. The annual Arietid meteor shower emerges from a point in the sky only 30 degrees from the sun. These meteors are thought to be debris from the sungrazing asteroid Icarus.
Arietid meteoroids hit Earth's atmosphere with a velocity of 39 km/s (87,000 mph). No one is sure where these meteoroids come from, although some astronomers suspect they are debris from the sungrazing asteroid 1566 Icarus.
The debris stream is quite broad: Earth is in it from late May until early July. In most years, the shower peaks on June 8th.
During one hour on the morning of June 2, 1973, John West (Bryan, Texas) observed four Arietids.
Various researchers have arrived at some interesting conclusions concerning links between this stream and other solar system bodies. In 1951, while obtaining the first determination of this stream's orbit, Almond concluded that another shower should be encountered as Earth crossed the stream's orbital plane on July 28. The estimated radiant position was RA=336 deg, DECL=-11 deg, which falls within 15 deg of the position of the Southern Delta Aquarid meteor stream. After examining both stream orbits, Almond concluded that, although the orbits "are now different, it seems probable that they may have had a common origin in the past."
In articles published during 1973 and 1976, Zdenek Sekanina suggested several possible associations of meteor streams with comets and asteroids. For the Arietids, he noted that the Apollo asteroid Icarus (1566) possessed an orbit with similar characteristics.
Reference:
http://www.spaceweather.com/meteors/arietids/arietids.htm
http://cache.aftenposten.no/multimedia/archive/00410/_A-Meteoritt_6sek_j_410790h.jpg
http://neo.jpl.nasa.gov/cgi-bin/db?name=1566+Icarus
http://www.spaceweather.com/meteors/arietids/images/skymap_north.gif
http://cache.aftenposten.no/multimedia/archive/00410/_meteoritt_jpg_410803h.jpg
http://www.norsar.no/NDC/bulletins/gbf/northnorway.jpg
http://en.wikipedia.org/wiki/1566_Icarus
http://comets.amsmeteors.org/meteors/showers/daytime_arietids.html
Is this the one that was supposed to kill us all on May 25th?
NASA says comet fragments won't hit Earth
(Apr 28, 2006)
Chunks of a comet currently splitting into pieces in the night sky will not strike the Earth next month, nor will it spawn killer tsunamis and mass extinctions, NASA officials said Thursday. The announcement, NASA hopes, will squash rumors that a fragment of the crumbling Comet 73P/Schwassmann-Wachmann 3 (SW 3) will slam into Earth just before Memorial Day. “There are some Internet stories going around that there’s going to be an impact on May 25,” NASA spokesperson Grey Hautaluoma, told SPACE.com.
Reference:
9K
29K
9K
