Understanding Eutectic Point: Definition and Calculation
The discussion revolves around the concept of the eutectic point, focusing on its definition and calculation. Participants seek clarification on the topic, referencing external sources for further understanding.
  • Some participants inquire about the definition of the eutectic point, indicating a lack of clarity on the topic.
  • One participant summarizes that a eutectic mixture is characterized by having the lowest melting point and that phases crystallize simultaneously from a molten solution at this temperature.
  • Another participant suggests that the steel (Fe - C) system serves as a better example for understanding eutectic points.
  • Several participants share links to external resources, including Wikipedia articles and other forums, to provide additional context and explanations regarding eutectic points and phase diagrams.
Participants generally express confusion about the eutectic point, and while some provide explanations and resources, no consensus on a clear understanding emerges from the discussion.
Participants reference various external sources, indicating that their understanding may depend on the clarity and completeness of those definitions and diagrams. There is also an indication that the discussion may be limited by the participants' prior knowledge of phase diagrams.
chound
What is eutectic point?
Chemistry news on Phys.org
Actually I read that but couldn't understand what was written that's why I posted here
chound, what is not clear in the wikipedia article.
The key point is:
A eutectic or eutectic mixture is a mixture of two or more phases at a composition that has the lowest melting point, and where the phases simultaneously crystallise from molten solution at this temperature.
In the two phase diagram given, the eutectic is found at the "V" of the liquid phase, where the vertex touches the horizontal line. The horizontal line represents a constant temperature, and the vertex represents a specific composition. The eutectic represents the point where that composition goes 'directly' from solid to liquid, i.e. without partially melting to a solid-liquid combination.
The example of the steel (Fe - C) system is perhaps better.
http://en.wikipedia.org/wiki/Eutectic#Eutectoid
This figure shows the eutectic and eutectoid.
Then there is a three-phse reactions diagram below that:
http://en.wikipedia.org/wiki/Image:Three-Phase-Reactions.png ,
which should be more clear.
Here is another site which discusses binary phase diagrams.
http://csmres.jmu.edu/geollab/Fichter/IgnRx/BinryEu.html
Look at this post from another forum. It may be helpful.
http://www.scienceforums.net/forums/showpost.php?p=183126&postcount=20
