Is there a method to input new substances into HYSYS?
  • Thread starter Thread starter jaxnnux
    Input Method
To input new substances into HYSYS, users can utilize the hypothetical components feature found in the basis environment. This allows for the creation of components not included in the HYSYS library, such as glucose for ethanol production processes. Essential data, including the normal boiling point (NBP) of the new component, must be provided for HYSYS to estimate additional properties. Resources like Perry's "Handbook of Chemistry and Physics" and the AspenTech support center offer valuable information for this process.
  • Understanding of HYSYS software and its interface
  • Knowledge of hypothetical components in process simulation
  • Familiarity with thermodynamic properties, specifically normal boiling point (NBP)
  • Access to chemical property databases, such as Perry's Handbook
  • Research how to create hypothetical components in HYSYS
  • Learn about entering thermodynamic properties for new substances in HYSYS
  • Explore the AspenTech support center for additional resources and tips
  • Study the use of Perry's "Handbook of Chemistry and Physics" for chemical property data
Chemical engineers, process simulation specialists, and students working on projects involving HYSYS and the conversion of biomass to biofuels.
jaxnnux
Hello,
I am doing a senior design project on converting corn into ethanol. I would like to perform my mass and energy balances on hysys. However, HYSYS does not have glucose and many other streams of substances that would be flowing through our process. Is there a method to input new substances into HYSYS?
Thanks so much.
Have you tried their support center?
The HYSYS literature indicates that is primarily for petroleum, but there should be a way to add other materials/properties. However, I am not familiar with the application/software.
use hypocomponents
There is a feature in HYSYS where you can use to generate components which cannot be found in the HYSYS library.
Goto basis environment and create hypothetical componet for your new components.
Perry and "Handbook of Chemistry and Physics" will have a bit of date for some of the components.
You will require to enter at least the NBP for the new component for HYSYS to estimate the rest of the properties for you.
I found http://support.aspentech.com has useful tips to use HYSYS.
Hope this helps.:smile:
Brian, just got married with Eve. :biggrin:
http://www.behappytogether.com
  • · Replies 131 ·
11K
  • · Replies 74 ·
11K
9K
  • · Replies 19 ·
