Simple force question that I cant get
  • Thread starter Thread starter mikejones2000
    Force
The discussion revolves around calculating the frictional force on a 1 kg block with coefficients of static friction (μs=0.64) and kinetic friction (μk=0.42) under different conditions. For part A, the frictional force is zero since the block is at rest on a horizontal surface. In part B, the frictional force is determined by the normal force, which is affected by the incline, and the calculation must include the gravitational component acting parallel to the incline. In part C, the same principle applies, but the block is moving downwards on a steeper incline, requiring careful consideration of the forces involved.
  • Understanding of Newton's laws of motion
  • Knowledge of friction coefficients (static and kinetic)
  • Basic trigonometry for resolving forces on inclined planes
  • Familiarity with free body diagrams
  • Study the concept of normal force in inclined planes
  • Learn how to calculate frictional forces in various scenarios
  • Explore the effects of different angles on frictional force calculations
  • Review examples of free body diagrams for complex systems
Physics students, educators, and anyone interested in understanding the principles of friction and forces acting on objects in motion.
mikejones2000
I know I got at least two out of the three incorrect and cannot seem to understand why.
The question states:
The coefficients of friction between a block of mass 1 kg and a surface are μs=0.64 and μk=0.42. Assume the only other force acting on the block is that due to gravity, what is the magnitude of the frictional force on the block
A)if the block is at rest and the surface is horizontal?
B)if the block is at rest and the surface is inclined at 22o?
C)if the block is at moving downward and the surface is inclined at 49o?
For a) I said the magnitude is 0 because there is no force acting on it other than gravity and for b) I put .64-9.8sin(22) and c).42-9.8sin49. I got two negative numbers for b) and c) and probably think those are the ones I screwed up on but cannot understand how if the only other force acting on it is gravity and not a normal force. Any help would be greatly appreciated.
I think you took them too literally when they said "Assume the only other force acting on the block is that due to gravity". Of course there's a normal force, otherwise the frictional force will always be zero. They meant no other applied forces, like someone pushing or pulling the block.
  • · Replies 36 ·
