Best Tool to Cut a Large Bar of Soap in Half
  • Thread starter Thread starter larkspur
    Cut Soap
The discussion revolves around the best method to cut a large bar of soap in half, specifically a triple milled soap measuring 11cm by 7cm by 4cm. Participants explore various tools and techniques for achieving this, considering practical applications and safety concerns.
  • One participant suggests using a miter box and saw or a hacksaw, questioning which would be more effective.
  • Another proposes a serrated bread knife, recommending heating it to reduce crumbs while cutting.
  • A humorous suggestion is made about using a big hammer to break the soap instead of cutting it.
  • Safety concerns are raised regarding the slipperiness of the soap when wet and the importance of securing it while cutting.
  • One participant shares their successful experience of microwaving the soap before cutting, noting that it made the process easier and cleaner.
  • Several participants reminisce about carving soap and other materials in childhood, sharing personal anecdotes related to the topic.
  • There are mentions of using cheese slicer wires and the effectiveness of different knives for cutting soap.
  • Some participants express curiosity about the practicality of such a large bar of soap and its origins.
Participants express a variety of methods and tools for cutting the soap, with no clear consensus on the best approach. Some suggestions are more serious while others are humorous, indicating a mix of practical and playful contributions.
Participants discuss the properties of the soap, such as its triple milled nature, which affects its cutting characteristics. There is also mention of the potential for different outcomes based on the type of soap used.
This discussion may be of interest to individuals looking for practical advice on cutting soap, as well as those interested in DIY projects or childhood crafting experiences.
larkspur
What would be the best way to cut a very large bar of soap in half? I have a bar of triple milled soap that is 11cm long, 7cm wide and 4cm thick. My hands too small to hold on to this bar in the shower.
I have a miter box and the saw that came with it or a hack saw. Which one would be best to use?
I suspect that just a serrated bread knife would do nicely. Heating it will let it melt a bit rather than just sawing through. Fewer crumbs that way. Even one of those cheese slicer wires might work.
I'll bet you could break it in half.
Well, I'll bet someone who doesn't have tiny hands could anyway...
Caution, slippery when wet.
If you are going to cut it with a knife, put it in a vise so that it does not slip away as you are applying pressure. You might slice your hand real nice.
Well, since the application doesn't really require cutting it in half, just something smaller you can grab with your hands in the shower...a big hammer should do the trick. :devil:
Where on Earth did you acquire such a ginormous bar of soap in the first place? Did someone really think this was practical?
My Mom gave it to me for Christmas because it came in a cute yellow metal box...Reminds me of a lunch box I had in first grade.:smile:
The mitre saw should work nicely. And please, cut it dry.
I decided to try Danger's idea and heated the bar in the microwave until it began to blow bubbles out the ends(41 seconds). Then I took my Ginsu type knife and cut it in half. After it was heated it cut like butter- no crumbs either.
Thanks for the input everyone!
Gotta love a Ginsu!
I used to carve animals out of soap bars when I was little. Had a fairly dull knife that was great for whittling the soft soap.
I also used to carve blocks of balsa wood. It was great for carving replicas of viking ships and old sailing ships.
You all did that, right? :rolleyes:
We had to do that for art class when I was little. I don't remember what I wanted to carve, but I know it never looked anything like it. :rolleyes:
That's what I thought this thread was about. Ivory soap was great for carving.
I also made little insects out of pieces of pine and toothpicks and carved a chess set out of pine and walnut.
Guess that wasn't an air-blown soap (like Ivory). With one of those, all you'd have after 40 seconds in the microwave is an ovenfull of foam.
Cheeeeeeeeeeese wire!
Self-cleaning cycle, if you will.
:smile: Hey, my microwave needs that! :smile:
:smile: :smile: :smile: :smile:
Nope, it was "triple milled" so there is very low air and water content.
  • · Replies 39 ·
17K
  • · Replies 42 ·
