| Thread Closed |
Photon spin - where is the missing state? |
Share Thread | Thread Tools |
| Jan10-04, 04:36 AM | #1 |
Photons have spin 1, yet only show two possible spin values along the direction of travel. For a spin 1 particle there should be three possible values, along the direction of motion, away from it and zero. What happens in the wave equation solutions to stop the zero spin state from coming into existence???
| Jan10-04, 04:21 PM | #2 |
for one thing, the classical electromagnetic wave must be transverse, by Maxwells equations. thus, the classical wave has only 2 degrees of freedom, so the corresponding quantum particle better also have 2 degrees of freedom, or else we are in trouble. that number 2j+1 is the dimension of the rotation group for a spin-j particle. it counts how many degrees of freedom a spin-j particle has in its rest frame due to spin. however, the photon, being massless, always travels at the speed of light, and therefore doesn t have a rest frame. to count the degrees of freedom of a particle, we start with the Poincaré group, and look for its representations. for a massive particle, we can find those by going to the rest frame, and we find 2j+1 degrees of freedom, since in the rest frame, the Poincaré group reduces to the rotation group (the rotation group SO(D-1) is the little group of the Poincaré group ISO(D-1,1) for a massive particle) but for a massless particle, we cannot go to a rest frame. instead, we go to a frame where the momentum of the photon is (1,1,0,0,......,0), and here, the symmetry group is SO(D-2). this has one fewer degrees of freedom for a spin-1 particle. another way to see it is to look at how we quantize the photon. we start with a vector field, which actually has 4 degrees of freedom. but gauge invariance forces 2 of these degrees of freedom to be unphysical. gauge invariance again relies on the photon being massless. in short: the photon loses that degree of freedom because it is massless. |
| Jan10-04, 05:10 PM | #3 |
Lethe, that's a great explanation - many thanks. I had suspected it must all be down to the zero mass of the photon. Is there any similar impact on spin states for the spin 1/2 neutrino?
I like the argument around the Poincare group. Is there a spin-1 version of the Dirac spin 1/2 equation? I would really like to work through the algebra and see all this fall out, like the spin states of the electron do for spin 1/2. I would much prefer to see it done that way - the argument around the photon transversality in the classical Maxwell equations is all well and good, but I don't understand how those translate directly via the Correspondence Principle from a vector field to a wave function....... |
| Jan11-04, 10:45 AM | #4 |
No need for any answer to these questions - found a really great set of lectures on the representations of the poincare group and the resulting wave equations at:
http://www4.prossiga.br/lopes/prodcien/lectures/ Thanks for the hints that got me to go an look for this. |
| Jan11-04, 11:19 AM | #5 |
And thank YOU for the nifty link. I like to keep sites like this bookmarked - all the basic math on one topic boiled down for handy reference.
| Jan11-04, 12:07 PM | #6 |
The pleasure's mine. The URL is interesting - the lectures there are from the 1950's, and are part of a large collection of stuff by Leite Lopes, including some jointly authored with Richard Feynman.
| Jan13-04, 06:31 PM | #7 |
Recognitions:
| Jan14-04, 10:50 AM | #8 |
Lethe's argument on gauge invariance got me interested also. Basically, I think the argument here is two fold, firstly gauge invariance of the EM field and the zero-mass of the photon go hand in hand (otherwise the field equations are just not gauge invariant.) Secondly, if the EM field is gauge invariant, then you can show that it is possible to choose a gauge in which not just one but TWO of the four degrees of freedom vanish. This is followed through in detail here:
http://courses.washington.edu/phys55...0557_lec13.htm |
| Jan14-04, 01:08 PM | #9 |
Recognitions:
| Jan16-04, 06:13 PM | #10 |
| Jan16-04, 06:20 PM | #11 |
but i admit that i don t understand this as well as i would like, so if you can set me straight, i would appreciate it. |
| Jan16-04, 06:24 PM | #12 |
i will think about it (or maybe someone else will tell us) |
| Jan19-04, 10:02 AM | #13 |
Recognitions:
[Ai, Aj] = iεijkAk [Bi, Bj] = iεijkBk [Ai, Bj] = 0. We find matrices satisfying these in the same way that we find matrices representing the spins of a pair of uncoupled particles - as a direct sum. That is, we label the rows and columns of these matrices with a pair of integers and/or half-integers a, b, running over the values a = -A, -A+1, ⋅⋅⋅, A b = - B, -B+1, ⋅⋅⋅, B and take (A)a'b',ab = δbb' (J(A))a'a (B)a'b',ab = δaa' (J(B))b'b where J(A) and J(B) are just the standard matrices for spins A and B. The reps are then labelled by (A, B) and are (2A+1)(2B+1)-dimensional. The generators of the rotation group may then be represented by the hermitian matrices J = A + B. The usual rules of vector addition show that (A, B)-fields have components that rotate like spin-j objects with j = A+B, A+B-1, ⋅⋅⋅, |A-B|. For example, (½, ½)-fields have j = 1 and j = 0 components corresponding to the spatial and temporal parts of a 4-vector. It turns out that massless (A. B)-fields can be formed only from the annihilation and creation operators for massless particles of helicity ±σ in which σ = B - A. Since massless lorentz 4-vectors transform in the (½, ½), they can only describe helicity zero. However, the electromagnetic potential aμ(x) is a massless field of helicity ±1 and thus can't be a true lorentz vector, despite the lorentz index. In fact it transforms under general lorentz transformations Λ as U(Λ)aμ(x)U-1(Λ) = Λνμaν(Λx) + ∂μΩ(x,Λ) where U(Λ) is a unitary rep of the lorentz group and Ω(x,Λ) is a linear combination of annihilation and creation operators. As I mentioned, we can use fields like aμ(x) as ingredients in lorentz-invariant physical theories if the couplings of aμ(x) are not only formally lorentz-invariant (that is, invariant under formal lorentz transformations under which aμ(x) → Λμν aν), but also invariant under the "gauge" transformations aμ(x) → aμ(x) + ∂μΩ. This is achieved by taking the couplings of aμ to be of the form aμjμ, where jμ is a conserved 4-vector current, i.e. it satisfies ∂μjμ = 0. |
| Mar19-09, 06:02 AM | #14 |
Phonons are also massless bosonic (quasi)particles, but they have three spin degrees of freedom. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Photon spin - where is the missing state?
| photon spin | Quantum Physics | 17 | ||
| Photon spin ? | Quantum Physics | 0 | ||
| A question that bothers me - Photon spin up/down state? | High Energy, Nuclear, Particle Physics | 4 | ||
| photon spin | Quantum Physics | 13 | ||
| spin 2 and missing antimatter | Quantum Physics | 0 | ||
