How do you prove the relationship between electromagnetic and metric tensors?
  • Context: Graduate
  • Thread starter Thread starter Emanuel84
The discussion revolves around proving the relationship between electromagnetic and metric tensors, specifically focusing on the electromagnetic tensor \( F \), its dual \( G \), and their connections to electric and magnetic fields \( \mathbf{E} \) and \( \mathbf{B} \). The scope includes mathematical reasoning and technical explanations related to tensor calculus in the context of electromagnetism.
  • One participant requests assistance in proving several equations involving the electromagnetic tensor \( F \), its dual \( G \), and the metric tensor \( \eta \), including relationships involving \( \mathbf{E} \) and \( \mathbf{B} \).
  • Another participant suggests specifying the definitions of \( \mathbf{E} \) and \( \mathbf{B} \) in terms of field tensors and provides a method to express these vectors using an observer's 4-velocity.
  • A later reply reiterates the initial request and provides a straightforward approach assuming a Minkowski metric, detailing the components of \( F_{ab} \) and its inverse, along with a discussion on the closed exact 2-form field and the definition of the Hodge dual.
  • The same participant mentions that the required results can be found through direct calculation based on the definitions provided.
Participants present various approaches and methods for proving the relationships, but there is no consensus on a single method or resolution of the problem. Multiple viewpoints and techniques are discussed without agreement on a definitive solution.
Limitations include the need for clarity on definitions and conventions used for the tensors and fields, as well as the potential dependence on the choice of metric signature.
Emanuel84
Hi, I'm wondering how to prove the following...can you help me? :redface:
[itex] F^{\mu \rho} G_{\rho \nu} = \eta^\mu_{\phantom{\mu}\nu} \mathbf{E} \cdot \mathbf{B}[/itex][itex] F^{\mu \nu} F_{\mu \nu} = -2\left(\mathbf{E}^2-\mathbf{B}^2\right)[/itex][itex] G^{\mu \nu} F_{\mu \nu} = -4\,\mathbf{E} \cdot \mathbf{B}[/itex][itex] G^{\mu \nu} G_{\mu \nu} = F^{\mu \nu} F_{\mu \nu}[/itex]
[itex]F[/itex] is the electromagnetic tensor, [itex]G[/itex] is it's dual, [itex]\eta[/itex] is the metric tensor, [itex]\mathbf{E}[/itex] and [itex]\mathbf{B}[/itex] the electric and magnetic field respectively.Thank you for your patience! :wink:
You need to specify the definition of [tex]\vec E[/tex] and [tex]\vec B[/tex] in terms of your field tensors.
Up to sign, signature, and index-placement conventions, one can write
[tex]E_b=u^aF_{ab}[/tex] and [tex]B_b=u^aG_{ab}[/tex] for an observer with 4-velocity [tex]u^a[/tex]. By contracting with [tex]u^b[/tex], you can verify that these vectors are orthogonal to, i.e. "spatial according to" the observer with 4-velocity [tex]u^b[/tex]. You will probably need the spatial metric as well... up to conventions, write [tex]g_{ab}=u_au_b+h_{ab}[/tex] with the condition that [tex]u^a h_{ab}=0_b[/tex].
It's quite straightforward. If we assume a Minkowski metric [tex]\eta_{ab}[/tex] of signature [tex](-+++)[/tex] then the components of [tex]F_{ab}[/tex] can be expressed simply as
[tex] F_{ab}=\left(\begin{array}{cccc}<br /> 0 & -E_{x} & -E_{y} & -E_{z}\\<br /> E_{x} & 0 & B_{z} & -B_{y}\\<br /> E_{y} & -B_{z} & 0 & B_{x}\\<br /> E_{z} & B_{y} & B_{x} & 0\end{array}\right)[/tex]
with inverse
[tex] F^{ab}=\left(\begin{array}{cccc}<br /> 0 & E_{x} & E_{y} & E_{z}\\<br /> -E_{x} & 0 & B_{z} & -B_{y}\\<br /> -E_{y} & -B_{z} & 0 & B_{x}\\<br /> -E_{z} & B_{y} & -B_{x} & 0\end{array}\right)[/tex]
The thing about the field tensor is that it is actually a closed exact 2-form field. If we define a one-form field [tex]A=(-\phi,\mathbf{A})=A_adx^a[/tex], then the electromagnetic two-form is defined as [tex]F=dA[/tex] (you can show that the components of [tex]F[/tex] are exactly those given above. Now define the Hodge dual through its action on basis forms as
[tex]\star\wedge_{i=1}^{p}\omega^{a_{i}}=\frac{\sqrt{|g|}}{(m-p)!}\epsilon_{\phantom{a_{1}\ldots a_{p}}b_{1}\ldots b_{m-p}}^{a_{1}\ldots a_{p}}\wedge_{i=1}^{m-p}\omega^{b_{i}}.[/tex]
This immediately gives you an expression for the components of [tex]\star F[/tex], or what you call [tex]G[/tex]. You can then find the required results simply by direct calculation.
Thank you everyone! :approve:
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 50 ·
