Chemistry review questions-calculations
  • Thread starter Thread starter Aya
    Chemistry Review
The discussion revolves around a series of chemistry review questions and calculations in preparation for an upcoming exam. Participants seek assistance in verifying their calculations and understanding various concepts related to stoichiometry, gas laws, and solution concentrations.
  • Homework-related
  • One participant presents a series of chemistry problems, including calculations for molecular formulas, gas volumes at STP, and molarity of solutions.
  • Participants discuss the calculation of molarity for a glucose solution, with one suggesting a formula for molarity and another confirming the calculation.
  • There is a discussion about balancing chemical equations, particularly the reaction of hydrogen and oxygen to produce water, with differing opinions on the use of whole numbers versus fractional coefficients.
  • One participant expresses uncertainty about calculating the number of moles of oxygen required to react with a given amount of hydrogen and seeks clarification.
  • Another participant provides corrections and hints for the calculations, including the correct stoichiometric relationships in the reactions discussed.
  • There are multiple calculations presented for the same problems, leading to different interpretations and results among participants.
Participants generally agree on some calculations, such as the molarity of the glucose solution, but there are disagreements regarding the balancing of chemical equations and the interpretation of stoichiometric coefficients. Some calculations remain unresolved, and participants continue to seek clarification on specific points.
Some calculations contain errors or assumptions that are not explicitly stated, such as the use of incorrect molar masses or the application of gas laws without clear definitions of conditions. The discussion also reflects varying levels of understanding among participants regarding stoichiometry and solution preparation.
Students preparing for chemistry exams, educators looking for examples of student problem-solving, and individuals interested in chemistry calculations and concepts.
Aya
Hi, I have some reviw questions for the upcomming chemistry exam, the problem is I don't have the answers so can some one read through my work and check if it is wright? Thanks.
1. An anaysis of a valitile liquid showed that it wsa composed of 14.4%C, 2.37% H and 83.49% Cl. If 4.25 g of the liquid was vaporized and occupied 628 mL at 65 degrees celcuios and 112 kpa, what would be the molecular formula of the compund?
carbon
14.4% x 100g
= 14.4 g
m=14.4 g
n=1.199 mol
Mm=12.01 g/mol
hydrogen
2.37% x 100g
=2.37g
m=2.37 g
n=2.347mol
Mm=1.01 g/mol
Cholrine
83.49% x 100g
=83.49g
m=83.49 g
n=2.355mol
Mm=35.45 g/mol
so...
1.199 / 1.199 =1
2.37 / 1.1.99=2
2.355/ 1.199=2
Impirical Formula
C1 H2 Cl2
# mol of Impirical formula
PV=nrt
n=PV/rt
n=(112Kpa)(0.628L)/ 8.314kpaL/molL (388k)
n=0.025 mol
Molar mass of Impreical formula
Mm=m/n
Mm=4.25g/0.025 mol
Mm=170 g/mol
Molar mass of ( what is this the molar mass of?)
C1 H2 Cl2
84.93
Find a Factor
170g/mol/ 84.93 g/mol
=2
Molecular Formula
2(C1 H2 Cl2)
C2 H4 Cl4
2. A gas has a volume of 40.0 ml at 40 degrees celcuios and 95 Kpa. What will be its volume at STP?
gas
40.0 mL = 0.04L
40 degrees celcioue=313 K
95 kPa=P
n=rt/pv
n= 8.134(313)/95(0.04)
n=27.3890 mol
v=nrt
v=27.3809(8.134)(273)/101.3
v=613.4948
3. How many grams of sodium and required to product 2.24 L of Hydrogen gas, measured at 25 degrees celcuoiu adn 110 Kpa, according to the following reaction?
2Na + 2 H2O ---> 2 NaOH + H2O
n=rt/pv
n= 8.314(298)/110(2.24)
n=10.055
m=nMm
m=20.11 (22.99)
m=462.3289
B)calculate the volume of H2(g) produced when 54 g of Na(s) reacts with an excess of water at STP.
moles of Na
n=m/Mm
n=54/22.99
n=2.348
moles H
3.348/2
1.174
Volume
v=nrt/p
1.174(8.314)(273)/101.3
v=2.791
4. An aquois solution has a volume of 2.0L and contains 36.0 g of glucose. If the molar mass of glucose is 180 g , what is the molarity of the solution?
n=m/Mm
n=36.0/180
n=0.2
...what next?
5. How would you prepare 100ml of 0.40 mol/L MgSO4 form a stock solution of 2.0 mol/L MgSO4?
n=0.100L/0.40 mol/L
0.25
v=n/c
v=0.25/2.0
v=0.125L
add 0.125L of MgSO4
6. A solution contains 5.85 g of sodium chlride dissolved in 5.00 x 10^3 ml of water. What is the concentration of the sodium cholirde solution?
n=M/Mm
n=0.0568 mol
C=n/v
0.0568/5
=0.01136 mol/L
7.what mass of potassium hydroxide is required to prepare 6.00 x 10^2 ml of a solution with a concentration of 0.225 mol/L
m=cv
0.225(0.5)
0.135mol
8. What volume of 0.500mol/L sodium hyroxide solution can be prepared form 10.0 ml of a 6.00 mol/L solution?
C1V1=C2V2
6(0.01)=0.500(v2)
0.12=v2
9. What is the mass of hydrochoric acid that is present in 500 mL of a solution containg 3.50 mol/L of HCl(aq)?
n=cv
3.50(0.5)
=1.75 mol
m=nMm
1.75(36.46)
63.805g
10. Passing a park through a mixture of hydrogen gas and oxygen gas produced water
a) calculate the mas of hydrogen needed to completely convert 4.00 g of oxygen into water
H2 + O = H2O
moles of O
n=m/Mm
4.00/18.025
0.22
moles of H
0.22 mol
mass of H
m=nMm
=0.22(1.01)
=0.224
b) calcute the number of moles of oxygen required to react with 12.5 moles of hydrogen gas
I don't know how to do this one
c)calculate the number of moles of water produced when 4.00 g of oxygen are used
Thanks for reading pleas post any corrections and solutions to the problems I don't know how to do. this is practise for an exam so pleas help! :smile:
n=m/Mm
n=36.0/180
n=0.2
...what next?
HINT:
[tex]\text{M} = \frac{\text{moles}}{\text{volume}}[/tex]
You have almost already written the answer in your post, look again at the equation you written, i would just like to correct it however;
[tex]H_{2}_{(g)} + \frac{1}{2}O_{2}_{(g)} \rightarrow H_{2}O_{(l)}[/tex]
Now, all the answers you need are in the above equation. :smile:
M=Mol/vol
M= 0.2mol/2.0L
M=0.1mol/L
The teacher said we should only balance with whole nubbers so would it be
2H2 + O2 = 2H2O...?
moles of H
0.22 mol
sooo... moles of O is also 0.11mol?
2H2 + O2 = 2H2O
2 : 1 = 2
oxygen
n=M/mm
n=4.00g/16.0
n=0.25mol
Water
0.25mol x 2
=0.5 mol
Are these ones right, and is everything elce right?
Thanks for your help!
Aya said:
4.
M=Mol/vol
M= 0.2mol/2.0L
M=0.1mol/L
Spot on.
2H2 + O2 = 2H2O...?
If your teacher restricts you to using whole numbers, then yes that is correct, however using half a diatomic molecules is acceptable.
Aya said:
moles of H
0.22 mol
In you original post you said, 12.5 mols of hydrogen.
2H2 + O2 = 2H2O
2 : 1 = 2
oxygen
n=M/mm
n=4.00g/16.0
n=0.25mol
Water
0.25mol x 2
=0.5 mol
Yes, that's spot on! I'm afraid I haven't checked the other as I haven't really got time, my apologies; but if you check back later I'm sure someone will have obliged.
^ Oh, ok thanks for all your help!
13K
