Constructing a Pond/Tub for Humans & Fish: Is it Possible?
  • Thread starter Thread starter JasonRox
The discussion revolves around the feasibility of constructing a pond that accommodates both humans and fish, specifically exploring the challenges of maintaining water quality suitable for both. Participants consider various designs, filtration methods, and the implications of using chemicals in the water.
  • Some participants question whether it is possible to keep water clean enough for human use while also being livable for fish, noting that traditional methods may not work.
  • Concerns are raised about the use of chlorine and other chemicals, which could harm fish, suggesting that a physical barrier, such as a plexiglass divider, might be necessary.
  • Some propose that separating the human swimming area from the fish pond entirely might be a more practical solution.
  • There are suggestions for innovative designs, such as incorporating a bar into the divider or using double-layered plexiglass to insulate the fish from heat.
  • Participants express skepticism about the effectiveness of maintaining a clean system in a natural pond environment, citing issues like algae growth and the complexity of filtration systems.
  • Some argue that swimming in natural bodies of water is common and can be done safely, while others emphasize the risks of parasites and bacteria.
Participants do not reach a consensus on the best approach to integrating a human swimming area with a fish pond. Multiple competing views remain regarding the feasibility of shared water systems and the effectiveness of proposed solutions.
Limitations include the dependence on local conditions for water quality, the potential for chemical treatments to harm aquatic life, and the challenges of maintaining a clean system in an open environment like a pond.
This discussion may be of interest to individuals considering the construction of aquatic environments that serve dual purposes, as well as those interested in the ecological implications of such designs.
JasonRox
Alright, my friend has a small and will now be extending it a little bit.
I was thinking that he can make part of it as a semi-jacuzzi thing that blends into the pond (with fish).
The swimmers/human part of the pond will not be accessible by the fish (screen). Also, it will be cleaner. I was thinking a nice filter or somehting of the like.
My real question is...
...would it be possible to make the water clean enough for humans, but also liveable for the fish?
Biology news on Phys.org
It has been tother way round up till now, the humans will probably kill the fish.:smile:
I don't think fish are particularly fond of chlorine.
To keep it clean enough for humans, you would half to treat it with chemicals. The fish may not do so good with that. Why not put a plexiglass devider between them?
That sounds like a good idea.
Well people do swim/bathe in streams, rivers, lakes, oceans (in which fish live) - but there is a risk of getting parasites or bacteria depending on local concitions. It is always advisable to shower/wash after swimming in natural waters.
However, it is normal to use some type of disinfecting agent, such as chlorine in swimming pools and hot tubs/whirlpools where people congregate. The disinfectants are generally harmful to fish.
Hypatia has a great idea! Keep the waters separated and use a plexiglass or polycarbonate boundary (divider) - properly sealed.
Why not shoot the works and make the divider a bar (or at least a shelf to set your drinks on)?
Or maybe even put an entire bar on the divider
And have donald duck serving the drinks.
That's actually what I meant by the first part of the sentence, in the sense of building a bar out of plexi and having the working bits above the surface.
Just because 'cocktails' got their name from originally being garnished with feathers is no reason to expect that I want any in mine. :-p
Fish + poop = organic swimming pool
Short answer - no.
Why not simply separate the fishpond from the pool, while keeping them adjacent for aesthetic purposes? Seems cheaper than any separating barrier.
Some humans:rolleyes:
I don't see how one could ever get a clean system for human use in a "hole in the ground" application like a pond. Use of chlorine and other filtering strategies are only suited for systems that are self-contained units like a swimming pool or jacuzzi. The pond, being open to bacteria in the soil, air, etc, requires a much more complicated (and elegant) filtration/purification system. You'd be better off simply putting the two next to each other and appreciating them for the separate entities that they are.
A good observation, Doc, but I got the impression from the wording of the original question that the human part will be a construct rather than a simple hole. Since he said 'semi-jacuzzi', that rather implies to me that it will have walls and jets and filters and such. In fact, he could just cut one side out of commercial in-ground hot-tub and replace it with plexi, then dig the dirt away from that side to connect it to the pond. It wouldn't even have to be particularly strong as long as it's sealed properly; the water pressure should equalize more or less on both sides.
That's exactly what I was thinking, but then making the pond side more like aquarium type thing too. Not just a hole in the ground.
My observation was based on the two-way screen that was proposed to go between the "fish side" and the "human side". This would still facilitate exchange of unwanted material between the sides and not make either side a viable system. The plexi shield would technically work but what would it gain you? Most FW fish pond systems are plagued with algae problems which would hamper viewing and even if you could keep it clean entering the jacuzzi side is going to scare any fish away from the viewing port and turning on any water movement system is going to further obscure any underwater viewing. Plus the heat required to keep the jacuzzi comfortable for humans is going to be bad for fish. I have no problems with putting a sunken jacuzzi next to a pond, its sounds kinda fun, just keep them separate. Oh there's also the mousquito thing.
The algae shouldn't be a problem on the plexiglass if we keep it clean like an aquarium.
Plus, it can be a double layered plexiglass to insulate the fish from heat.
Note: Mosquitoes will not be a problem if the aquarium can continuously be filtered.
I figured that the whole point of having the fish was to eat the mosquitos. :-p
I see where you're coming from, Doc. I'd already latched onto Hypatia's plexi idea as a 'given', so water isolation was assumed. And Jason is correct that a double-layer of plexi will thermally isolate the bodies of water. It will mess up the view a bit due to multiple refractive indices, but that isn't too much of a hardship.
Nice use of big words...I woulda said "it won't be clear" because I am an idiot. :biggrin:
Since you can obviously spell your own name correctly enough to log in, you're brighter than me.
I do not know what all the fuss is about, have you never swam in a river
or fresh water pool, when i was younger a group of us used to swim in the
old cement pits, deep excavations now filled with water, with no ill effects,
so dig the biggest hole you can fill with water and fish and enjoy.
I don't know exactly where Jason's friend lives, Woolie, but almost all communities in Canada have building codes and zoning bylaws that govern how such things are constructed. Unless it's a rural area, I can pretty much guarantee that some form of concrete, metal or plastic is required as a container. There might even be drainage guidelines on the books if it's an area subjected to heavy rains, so's to make sure that he doesn't flood out his neighbours. Whatever method was used to make the pond is apparently within the rules, so should be acceptable for the addition as well.
  • · Replies 21 ·
13K
