Confirming: Is Electric Field Double between Oppositely Charged Plates?
The discussion revolves around the electric field between two parallel conducting plates, specifically addressing the effects of charging one plate versus both plates being oppositely charged. The original poster seeks clarification on the relationship between the electric field and charge distribution in these scenarios.
  • The original poster attempts to compare the electric field produced by a single charged plate to that of two oppositely charged plates, questioning the validity of their understanding of the equations involved.
Participants are exploring the implications of the equations used to describe the electric field, with some suggesting that the original poster may have misunderstood the application of Gauss's law. There is an ongoing examination of the assumptions made regarding the influence of the second plate on the electric field.
There is mention of the original poster's uncertainty regarding the use of LaTeX for mathematical expressions, which may have contributed to the confusion in their explanation. Additionally, the original poster indicates a need to revisit their understanding after an upcoming exam.
teilchen
obvious question IMO, but just need to make sure before test.
if you have two parallel conducting plates, and apply charge to one of them, then the field between them is half, compared to if the plates were acting as an air capacitor ie. both plates oppositely charged?
thing is, when I use a simplified version of gauss, the field on an infinite sheet of charge is
charge density/permittivity
which is the exact same as if I use
Q/V=[permittivity*plate area]/plate separation.
i tried to use latex, but I've never really used it, and it came out all wrong due bad syntax. sorry.
So what is your question?
whether the 2nd paragraph is correct...thought the question mark might've given it away. :P
Sorry. You said it like it was a true statement, which it is, and I didn't see the question mark. The second plate has no effect in this case, and the field is just that of a single charged plane.
ok, from common sense POV that's fine.
the further question i suppose, is why the two (bold) word equations simplify to the same thing, when one is for a single charged plane, and the other is for 2 opposing ones. (presuming I've made no mistake)
You're missing a factor of 1/2 in the first equation.
theeen my gauss is wrong...may have been the way I've learned it - via the "number of lines" instead of a formal mathematical integral.
when I learn my latex (after tomorrows exam then) I'll clarify what i meant.
ed: actually i think i figured out what I did wrong now, post tomorrow :D
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 58 ·
