Work Done by Force: A Physics Problem Solution
The discussion focuses on calculating the work done by various forces acting on a 2.8 kg block pushed 1.52 m up a vertical wall with a constant force F applied at an angle of 63.7 degrees. The gravitational acceleration is 9.8 m/s², and the coefficient of kinetic friction is 0.586. Key calculations include the work done by the applied force, gravitational force, normal force, and the increase in gravitational potential energy during the motion. The formula W = F.d is central to determining the work done.
  • Understanding of Newton's laws of motion
  • Knowledge of work-energy principles
  • Familiarity with friction coefficients and their applications
  • Basic trigonometry for resolving forces
  • Calculate work done by a force using W = F.d in various scenarios
  • Explore gravitational potential energy calculations in physics
  • Learn about the effects of friction on motion and work
  • Study vector resolution of forces in inclined planes
Students studying physics, educators teaching mechanics, and anyone interested in solving problems related to forces and work in physical systems.
heatherh1545
I have spent the last hour on this problem and I just can't seem to come up with the right answer:A 2.8 kg is pushed 1.52 m up a vertical wall with constant force of magnitude F applied at an angle of 63.7 degrees with the horizontal. The acceleration of gravity is 9.8 m/s (seconds squared) If the coefficient of kinetic friction between the block and the was is .586 find the:
a) work done by F
b) Find the work done by the force of gravity
c) Find the work done by the normal force between the block and the wall
d) by how much does the gravitational potential energy increase during this motion?
I assumed that I was on the right track when I was trying to find the force by using : F=mu*mg/ cos theta + mu sin theta
Hint : What are the different forces that the applied force has to overcome and what are their magnitudes and directions ?
W = F.d
PS: You might also want to delete your double post .
