Light clock and teaching of special relativity
The discussion revolves around the pedagogical effectiveness of the light clock as a tool for teaching special relativity. Participants explore its advantages and disadvantages, its relationship to Einstein's clocks, and the broader implications for understanding time dilation and other relativistic effects.
  • Some participants argue that the light clock is an excellent tool for qualitatively understanding time dilation.
  • Others suggest that the light clock approach may obscure its relationship with Einstein's clocks, which could be crucial for describing relativistic effects.
  • One participant proposes that using higher-dimensional light clocks and spacetime diagrams can enhance understanding of length contraction, simultaneity, and other concepts.
  • Another viewpoint emphasizes that the light clock is often used more for motivation rather than teaching the core concepts of special relativity.
  • Some express that the wristwatch analogy may be more helpful than the light clock for understanding proper time and its implications.
  • A participant questions whether there is an implicit assumption that Einstein's clocks are superior to light clocks.
  • Concerns are raised about the emphasis placed on motivating special relativity rather than teaching its principles directly.
  • One participant mentions the need to overcome preconceived notions about relativity before effectively teaching it.
  • There is a call for a more operational definition of time using light clocks, which some argue is a more physical approach.
  • Another participant seeks clarification on the difference between teaching and motivating in the context of special relativity.
Participants express a range of opinions on the effectiveness of the light clock, with no clear consensus on its pedagogical value. Some support its use, while others critique its effectiveness compared to alternative methods.
Participants note limitations in the treatment of light clocks in textbooks, suggesting that a purely spatial approach may not fully capture the necessary concepts of special relativity.
bernhard.rothenstein
do you think that the light clock is a good pedagogical tool for introducing special relativity? a teacher of mine told us that there is no advantage without disadvantage!
sine ira et studio
sine ira et studio
I, personallly, think that its an excellant tool. It allows one to understand time dilation qualitatively.
Pete
In fact, by using a higher-dimensional (e.g. circular and spherical) lightclock and drawing "spacetime diagrams of lightclocks", you can also do length contraction and relativity of simultaneity, as well as the doppler effect and twin paradox/clock effect... and you can do it by "counting ticks". In fact, one can highlight the invariance of the interval.
http://physics.syr.edu/courses/modules/LIGHTCONE/LightClock/
arxiv.org/abs/physics/0505134
One "problem" to overcome in teaching with "lightclock diagrams" is getting students to understand spacetime diagrams... and appreciate the geometry first, and (if necessary) the algebra later. The physical interpretation is much clearer when viewed geometrically first.
Pete
i think that the light clock approach obscures its relationship with the Einstein's clocks. the light clock, in its rest frame, is associated with two Einstein clocks located at the two mirrors respectively. They are located in front of Einstein clocks of the reference frame relative to which it moves. Taking them into account we are able to describe all the relativistic effects.
sine ira et studio
Is there an implicit assumption that "Einstein's clocks" are [necessarily] superior?
Of course, one advantage of the light clock is its operational definition of time along a worldline... using radar methods. This is arguably a "more physical" approach. This advantage has been raised in various references:
e.g.,
http://link.aip.org/link/?AJPIAS/37/178/1
American Journal of Physics -- February 1969 -- Volume 37, Issue 2, pp. 178-189
Operational Approach to Space and Time Measurements in Flat Space
James L. Anderson and Ronald Gautreau
(see others in the references of the article in my previous post)
Maybe I'm off base, but I feel like that a little too much emphasis is placed on motivating SR than teaching SR... the way I usually see the light clock used tends to fall in the motivation category.
In my opinion, one does have to overcome "that layer of prejudices laid down upon the mind prior to the age of eighteen" [AE]. At one extreme, one could simply teach SR without motivation by just stating that we are studying a vector space with a Minkowski metric... and taking it from there.
In my opinion, your observation on the light clock in the "motivation[-but-not-much-as-teaching] category" is due to the limited treatment of light clocks via purely-spatial diagrams in textbooks. As I said above, with a spacetime diagram approach, one can actually use the light clock to calculate (in some nice cases, counting ticks of) spacetime intervals, as well as provide a physical, operational meaning to them... rather than relying on [often specific cases of] merely algebraic formulas to obtain the usual results. (Of course, after sufficient conceptual and computational motivation with the spacetime light-clock diagrams, one can then shift the emphasis to the now geometrically-motivated algebraic formulas and deal with more complicated problems that are tedious to handle with diagrams.)
my $0.02
and quantitatively.
light clock
What is the meaning of I'm off base?. What is the difference between teaching and motivating?
I feel that too much emphasis is placed on answering the question "Why would we ever have thought of SR?" instead of answering the questions "What is SR?" and "How do we use SR?"
I didn't find light clocks very helpful really. The concept of the "wristwatch" was most helpful to me personally.
Of course, a "wristwatch" emphasizes that [proper-]time is a local concept associated with an observer [as opposed to a global time associated with "absolute time"]. This idea alone does not explain why the moving wristwatch is observed to behave differently from a wristwatch at rest. A light clock provides a relativity-friendly mechanism for the wristwatch's behavior.
Is there a simple one-line argument that says why time experienced by a massive observer between [itex][a,b][/itex]whose worldline is given by [itex]x^\mu(\lambda),[/itex] where [itex]\lambda[/itex] is a parameter is
[tex]\tau = \int^{\lambda=b}_{\lambda=a} d \tau = \int^b_a \sqrt{\pm\frac{dx^\mu}{d\lambda} \frac{dx_\mu}{d\lambda}} d\lambda\ \ \mbox{the sign depending upon the choice of metric}[/tex]
  • · Replies 59 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 40 ·
