AP Physics C Projectile Question
by Musicman
Tags: physics, projectile
Musicman
Musicman is offline
#1
Jun25-06, 03:50 PM
P: 21
A projectile is fired horizontally from a gun that is 63.0 m above flat ground. The muzzle velocity is 250 m/s.
(a) How long does the projectile remain in the air? (in seconds)
I got 3.96 s
(b) At what horizontal distance from the firing point does it strike the ground? ( in meters) I got 19.44 m
(c) What is the magnitude of the vertical component of its velocity as it strikes the ground? I got 187 m
because v(x) is a constant and v sub zero is zero in the vertical direction
i did 63=.5(9.8)t^2
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
Hootenanny
Hootenanny is offline
#2
Jun25-06, 03:52 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Quote Quote by Musicman
I got 3.96 s
What value are you using for g?
0rthodontist
0rthodontist is offline
#3
Jun25-06, 03:55 PM
Sci Advisor
P: 1,253
Part a. is correct, the other two parts are not. Where are you having trouble?
Musicman
Musicman is offline
#4
Jun25-06, 03:58 PM
P: 21
actually 3.58 s is the time
Hootenanny
#5
Jun25-06, 03:58 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Quote Quote by 0rthodontist
I think he's is off slightly, I get 3.58 seconds.
Edit: Just seen your revised post now Musicman
Perhaps if you show your working for the remaing two questions.
mrjeffy321
mrjeffy321 is offline
#6
Jun25-06, 04:00 PM
Sci Advisor
P: 882
I assume you want someone to check you answers?
For the first part, I used the formula,
d = -1/2 at^2
where d is the distance the projectile falls, a is the acceleration due to gravity (-9.81 m/s^2) and t is the time it takes to hit the ground.
63 m = -1/2 (-9.81 m/s^2) * t^2
t = sqrt (63 / 4.905) = sqrt (12.844)
t = 3.58 seconds
For the 2nd part, I used my answer for time in the first part along with this formula,
d = v*t
where d is the horizontal distance traveled, v is the constant horizontal velocity (250 m/s), and t is the time (3.58 s).
d = 895.96 meters
For part (c),
I assumed the horizontal component of the velocity was constant, only the vertical component changed from the intial to final states. To calculate the final vertical velocity, I used the following formula,
v = a*t
where v is the velocity after a constant acceleration (9.81 m/s^2 due to gravity) is experienced for a time t (3.58 s),
v = 9.81 m/s^2 * 3.58 s
v = 35.12 m/s
Then I added the two velocity vectors together (horizontal and vertical components) using the Pythagorean theorem to get the final, overall, velocity's magnitude,
v = 252.45 m/s
Hootenanny
#7
Jun25-06, 04:01 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Cum on mrjeffy, don't post complete solutions, we can't watch them squirm then!
PPonte
#8
Jun25-06, 04:04 PM
P: n/a
I get 3.58 seconds too.
Anyway: [tex]t = \sqrt{\frac{128}{g}}[/tex]
Musicman
Musicman is offline
#9
Jun25-06, 04:05 PM
P: 21
but for the 2nd part, wouldnt i use the vertical direction equation
x=(Vo)(t)?
Hootenanny
#10
Jun25-06, 04:07 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
x=(Vo)(t)?
The initial vertical velocity is zero. And besides, it is accelerating in the vertical plane (due to gravity). However, you do know that it takes 3.58 seconds to hit the floor. How far horizontally will it have travelled in 3.58 seconds? That is the range, you already know that is travels 63m in the vertical plane. Do you follow?
mrjeffy321
#11
Jun25-06, 04:09 PM
Sci Advisor
P: 882
All while I was typing, a bunch of stuff happened, I was just under the impression he wanted to compare his answers (assuming they were correct) with someone else's.
You initial vertical velocity is zero, so multiplying this by the time will give you zero distance.
Plus, perpendicular vectors (velocities) are independent....the vertical component of velocity does not [directly] effect the horizontal distance traveled.
PPonte
#12
Jun25-06, 04:10 PM
P: n/a
[tex]x_{max} = v_0t[/tex]
[tex]x_{max} = 250 * 3.58[/tex]
[tex]x_{max} = 895 m[/tex]
Register to reply
Related Discussions
Physics Experiment Question; Projectile Motion Introductory Physics Homework 4
Projectile Motion Physics I Introductory Physics Homework 2
physics projectile problem.... Introductory Physics Homework 1
Projectile Physics Classical Physics 10
Hard projectile physics question General Physics 1
