What Happens to the Voltage When Capacitors Are Connected Together?
The discussion revolves around the behavior of capacitors when connected together after being charged to the same voltage. Specifically, it involves a 50 pF capacitor and a 200 pF capacitor, both charged to 2.6 kV, and the implications of connecting them in parallel versus reversing their polarity.
  • Participants explore the conservation of charge and the effects of connecting capacitors with the same voltage. Questions arise regarding the implications of connecting them with reversed polarity and the resulting changes in voltage and energy stored.
The discussion is ongoing, with various approaches being suggested. Some participants provide insights into the conservation of charge and equilibrium conditions, while others question the initial assumptions about the connection method and the implications of polarity reversal.
There is uncertainty regarding the initial conditions of the capacitors and whether they were charged in series or parallel. The potential effects of reversing the polarity before connection are also under consideration.
renanpo
A 50 pF capacitor and a 200 pF capacitor are both charged to 2.6 kV. They are then disconnected from the voltage source and are connected together, positive plate to positive plate and negative plate to negative plate. Find the resulting potential difference across each capacitor.
I can find Q on each capacitor by using Q=VC. The Q total will be Q1+Q2, but I am not sure what to do from here. Could anyone give me some help? Thank you
If they have the same starting voltage and are connected together in parallel, there wil be no change in voltage, right? The harder question is what happens if they are reversed in polarity before being connected. Quiz question -- what is the final voltage if they are connected with reverse polarity. Harder quiz question -- discuss the energy stored before and after the connection -- where did the energy go?
conservation of charge:
q1+q2=qtotal
if the polars are different, then... just make one negative.
add the initial charges and you'll get qtotal
then, at equilibrium,
V1=V2
q1/C1=q2/C2
q1+q2=qtotal
solve the system, find V1 using V1=q1/C1
now you have final charge and final voltage, you can find anything from there.
Another way of looking at the question as set:
If the voltage is the same across both, there will be no potential difference, there fore no charge will flow from one to t'other, therefore no overall change at all.
Is the question right or were they charged in seriesor as berkemann sadi is it a case of reversing the capacitors?
EaGG
  • · Replies 18 ·
