How Are Dark Fringes Calculated in Newton's Rings Experiment?
The calculation of dark fringes in Newton's Rings Experiment is derived from the interference of light reflected between a convex spherical glass and a plane glass. The radii of the dark fringes are given by the formula r = √(mRλ), where λ is the wavelength of light and m = 0, 1, 2, ... The analysis involves understanding the phase shift of light reflecting from different layers and applying the condition for destructive interference, leading to the relationship t = mλ/2. A more accurate approach involves using the circular cross-section equation to derive the relationship between the radius and thickness of the air gap.
  • Understanding of Newton's Rings and interference patterns
  • Familiarity with phase shifts in light reflection
  • Basic knowledge of geometry and trigonometry
  • Ability to manipulate algebraic equations
  • Study the derivation of the Newton's Rings formula in detail
  • Learn about phase shifts in optics and their implications
  • Explore the geometry of circular cross-sections in physics
  • Investigate applications of interference patterns in modern optics
Students and educators in physics, optical engineers, and anyone interested in the principles of light interference and its applications in experimental setups.
jdstokes
Newton's rings are observed in monochromatic light reflected from the air gap between a convex spherical piece of glass (radius of curvature R) and a plane slap of glass. The two pieces are in contact in the centre.
(b)
Show that the dark fringes have radii given approximately by [itex]r= \sqrt{mR\lambda}[/itex] , lambda is the wavelength of the light and m = 0,1,2...
My solution:
Locally it can be regarded as an air gap of thickness t, separated by two parallel sheets of glass. The light reflected from the top layer of the air experiences no phase shift whereas the light reflected from the bottom suffers a pi rad phase shift since it encounters a more dense medium. Hence the condition from destructive interference is
[itex]2t = m \lambda[/itex] where m = 0,1,2,...
so
[itex]t = \frac{m \lambda}{2}[/itex].
Want to show that
[itex]r = \sqrt{2tR}[/itex]
WTS
[itex]t = \frac{r^2}{2R}[/itex].
The arc length along the spherical piece of glass is [itex]s = R\theta[/itex] which is approximately the distance along the flat piece of glass (r). So [itex]r \approx R\theta[/itex].
Then from the right-handed triangle I get [itex]\tan\theta = t/r[/itex] which for small theta is approximately theta. Hence,
[itex]r \approx R\theta \approx R\frac{t}{r}[/itex] so
[itex]t \approx \frac{r^2}{R}[/itex]
which is off by a factor of 1/2. Any ideas on this one?
Thanks in advance
James
I don't quite follow your equating the arc length with the radius of the circles. Instead, write the equation of the circular cross section:
[tex](y - R)^2 + x^2 = R^2[/tex]
(where the center of the circle/sphere is at (0,R))
Of course, y = t & x = r, so:
[tex](t - R)^2 + r^2 = R^2[/tex]
Solve for r to first order in t (ignore higher order terms) and you'll get your answer.
Thanks Doc Al. That's a much better method.
14K
