How the suggestion to found the time travel award
The discussion revolves around the concept of time travel, particularly focusing on the idea of negative mass and its potential implications for creating a time travel mechanism, such as a wormhole. Participants explore theoretical frameworks, challenges, and speculative ideas related to negative energy and mass, as well as the feasibility of time travel based on current understanding in physics.
  • Some participants propose that negative mass structures could facilitate exceeding the speed of light, potentially enabling time travel.
  • Others argue that negative energy production is necessary for time travel, but currently, there is no clear method to achieve this.
  • A participant distinguishes between negative mass and negative energy, suggesting that relativity may not apply in the context of negative mass.
  • Another participant discusses the theoretical properties of wormholes and the challenges in forming a macroscopic wormhole suitable for human travel.
  • There are mentions of tachyons as hypothetical particles associated with negative mass, which would always travel faster than light, but their stability and implications are questioned.
  • One participant introduces a model involving L-S-E waves and generators to propose a mechanism for time travel, suggesting that it may involve manipulating dimensions.
Participants express a range of views on the feasibility and theoretical underpinnings of time travel, with no consensus reached on the validity of negative mass or energy concepts, or the practicality of proposed mechanisms.
Discussions include unresolved assumptions about the nature of negative mass and energy, the applicability of relativity in these contexts, and the speculative nature of the proposed time travel mechanisms.
hey.like
To get into time travel, the negative mass structure is reasonable as it is ease to exceed the c. This is a very hard question. The negative mass traveler invention and patent would be awarded. Is it right the ten millions money award.
Who can do it ready ? Help please!
Boy that's the 64 femtomillion buck question. Negative energy production would be the prize, but nobody right now has a clue of how to do it. Most of those who are erven trying are pretty far over toward the crank direction. Sarfatti keeps posting but if you follow his posts over the last couple of years, you find he's stuck and won't admit it. He's go a cute idea for his derivation of the dynamical cosmological constant [tex]Lambda[/tex], but it's just definition, definition, definition (and squabbles with Hameroff, the ZPE man). No conclusions, no methods.
Boy that's the 64 femtomillion buck question. Negative energy production would be the prize, but nobody right now has a clue of how to do it. Most of those who are erven trying are pretty far over toward the crank direction. Sarfatti keeps posting but if you follow his posts over the last couple of years, you find he's stuck and won't admit it. He's go a cute idea for his derivation of the dynamical cosmological constant [tex]\Lambda[/tex], but it's just definition, definition, definition (and squabbles with Hameroff, the ZPE man). No conclusions, no methods.
Thank you reply carely!
Thank you to reply, I think. the negative mass is different the nagative energy, as the relativity is not right in negative mass . energy is not equal the mass. as some secret event like UFO and so. it is fast perhaps.
Thanks.
As careful a reply as I can do
Thanks.
Mmmm I think relativity is still valid. With negative energy, positive mass you have [tex]e^2 < p^2c^2 - m^2c^4[/tex], which is the condition for a virtual particle in the quantum vacuum. On the other hand a negative mass particle is a tachyon, which is a perfectly good relativistic particle that always travels faster than light. Just as we can't accelerate up past the speed of light to its domain of speed, so it can't decelerate down past the speed of light to ours. Same reason in both cases; it takes an infinite amount of energy to do that.
Warning. Many string and brane theories predict tachyons, but they also predict that they would be unstable and collapse the quantum vacuum to a lower energy level. Since that would be sort of like the end of the world, we don't want to see it happen.
Is The negative mass in a worm hole?
I read the negative mass is in a wormhole in www.[/url] sciam.com and search by [url]www.google.com.[/URL]
Now it is a hot direction. but it is puzzle.
As the relative theory and in a mini wormhole, Is the negative mass true in a worm hole?
[How could one build a time machine? The simplest way currently being discussed is to take a wormhole (a tunnel connecting spatially separated regions of space-time) and give one mouth of the wormhole a substantial velocity with respect to the other. Passage through the wormhole would then allow travel to the past.
"Easily said--but where does one obtain a wormhole? Although the theoretical properties of wormholes have been extensively studied over the past decade, little is known about how to form a macroscopic wormhole, large enough for a human or a spaceship to pass through. Some speculative theories of quantum gravity tell us that space-time has a complicated, foamlike structure of wormholes on the smallest scales--10^-33 centimeter, or a billion billion times smaller than an electron. Some physicists believe it may be possible to grab one of these truly microscopic wormholes and enlarge it to usable size, but at present these ideas are all very hypothetical.
REF: ASK THE EXPERTS : PHYSICS
According to current physical theory, is it possible for a human being to travel through time?
Cassandra Kelly
Kanata, Ontario, Canada ]
If the first time travel structure is like a wormhole, it is based in mass: positive mass structure. and to return as the positive mass structure.
The negative mass structure mechanism
As the wormhole is a negative mass structure model. the L-S-E wave is a hole model like the wormhole, in its inside wall, there are some negative mass to lead the speed fast light. It is the l-s-e wave to fast the light mechanism. The base wormhole genreators side should be two L-S-E generators to pass the L-S-E wave, as the safety reason, it is not to pass the earth. As the negative mass action, it is bent ease, and to pass some mass is ease, in future, some satellites is ease to send to the everywhere in sun systems. It is a plan to travel exceed light ease only.
To travel in time is a another question. that will be to rise or down the dimension first. ref the rising and down dimension mechanism in the title:For colour question by HEY.LIKE, that should more than 6 L-S-E generators for time dimension to inside and return from the different time spaece unit. If the time travel is ease, naturely it is fast than light first. It is ease to sent a satellaite to the near sun star, evenif it is far away 11 light-years. The true galaxy time will come belong the humans.
After time travel, A Bosom friend after brings a distant land near.
  • · Replies 21 ·
  • · Replies 95 ·
  • · Replies 17 ·
  • · Replies 125 ·
9K
